I want to put a Amber inst. Temp controller with rampsoak ssr output. I understand this is possible?
I have a good kiln Skutt L T -3K . I bought a Auber PID temperature controller with 30 ramp\soak. I want to do glass fusion and need temp heat and cool down time schedule. Can anyone give me any input of direct me to a who? I'd appreciate any help offered.
Posted by Mac Carter on
  • Anonymous Oct 31, 2021
    wow a kiln, question posted to COMPUTER REPAIR HELP'
    TRY HERE
    CLOSEST IS OVENS
    https://www.fixya.com/troubleshoot/brows...
    WHY NOT ASK THE KILN MAKER DIRECTLY FOR HELP AND WE ARE NOT THEM.
  • LouiseCaldwell
    LouiseCaldwell Dec 22, 2021
    I get paid more than ??$140 to ??$1000 per DAYS for working online. I heard about this job 3 months ago and after joining this I have earned easily $24652 from this without having online working skills .
    Simply give it
    open this link HERE……. >>>http://Www.NETCASH1.Com
Larry Ng
  • Computers & ... Master
  • 6,585 Answers
CALL THEM
ASK FOR AN UP GRADE
OR RELOAD WINDOWS AND REBOOT.
Posted on Dec 22, 2021
I need a users manual for a paragon kiln model Q11A SN 360917. The manual control box is on the side. The kiln is approximately 12 years old
Paragon Industries has the manual for the Q11A Kiln on the product page: http://www.paragonweb.com/Q11A.cfm . The direct link to the manual is currently http://www.paragonweb.com/files/manuals/IM-112_E_&_Q_Inst_&_Service_Manual.pdf . The manual covers several models of Paragon kilns.
I hope this helps.
2answers
How to determine kiln brand
Check and see if there is a model number, serial number or barcode number on the kiln. Usually if you just put the number into a search engine e.g. Google, it can find the manufacture, etc.
I need an owners manual for modet lt-3k kiln
Do you mean the Dawson LT-3K kiln sitter, a control and monitor for the ceramic kiln? The manual for this is on the product page: http://www.paragonweb.com/ManualInfo.cfm?CID=42 . The direct link to the manual is http://www.paragonweb.com/files/manuals/ACF1B.pdf .
If you need information about the kiln, then please check that model number and add a comment with that information. If your kiln is from Paragon, then try http://www.paragonweb.com/Instruction_Manuals.cfm for a manual. Paragon makes the Dawson LT-3K.
I hope this helps.
I am buying a ceramic kiln. What is the max Kw output I can use with standard single phase UK household supply?
You will get that information from the company you are buying the kiln from in there specs
1helpful
A friend who blind has purchase this item some time ago 2007 I believe. We have a number problems with it. 1/ There is a hum of 50 c/s from the deck (I assume from Mains Transformer) when switched on and...
initially it sounds like a ground hum Something is touching ground inside. have you had it open? Look at the out put SSR's and follow them to the out put jacks. can you replace the jacks if need be? have you tried different cables? Does it do it if you use another deck other than the Onkyo. If all looks good and you think the Onkyo is the issue you may have bad IC SSR(s). Do you have the Tech ability to replace the outputs {solid state relays}?
Let us know what conclusions you have come up with. Other wise the sad part is a $110 dollar repair bill or $189 new amp/deck.
Why does internal fuse on stafford 501 controller keep blowing
http://www.staffordinstruments.co.uk/files/install501.pdf
From the manual
This indicates an electrical fault in the control
circuit. The kiln has been on zero power for 15
minutes but the temperature has not fallen by at
least 1°C. Control contacts may have failed closed (e.g. welded). TURN OFF THE KILN [Error 4 should be present]
Nov 10, 2014 • Baby Gear
The set Code button on my Cress E27 kiln quit working, so I need a wiring diagram to determine if q wire is disconnected or corroded
Could you let me know if its the stock Cress controller or other controller. I have the schematics to a Skutt controller. They operate some what the same. Knowing the voltage and phase of your electrical supply connection would tell me what to send you.
Stevan
[email protected]
Hi, I don't understand how the early and late boost works on the storage heater. Someone told me I should turn the output switch off when I am at work during the day, then turn the output control up when I...
Output switch is the one that says Cool-Off-Heat. Turn this offwhen you aren't home.
Output control is the thermostat. If you want to heat the room turn up the thermostat to the desired heat after putting the output switch on heat. It will take a few minutes for the heater to get hot. Early boost would be if you want immediate higher blower speed to speed up keep the heated air from being too hot and late boost will hold off the fan until the heater is higher in temp and the air temp discharged will be hotter.
Computers & Internet Logo
Ekse
