Question about Tablets & eReaders
Hi! My Computer tablet doesnot work. The homescreen does not move. It can be turn on though but up to the homescreen only. Please help,whay do i do....
Posted by RENALYN TALAMAYAN on
Daniel Alonso
What is the Windows Registry?
The Windows registry is a storage database of files and configurations that are used to run all software and hardware on your system. In many ways it is the "lifeblood" of your computer, since nothing can run without first accessing data within the registry. Over time, the registry will become bloated with errors and require maintenance in order to improve PC performance.
How Can I Fix the Registry?
Unfortunately the registry is an extremely complicated section of your system. Attempting to fix it manually is only recommended for folks who are computer experts. If you remove or uninstall the wrong registry entry or value, the entire system can collapse. This is why it is highly recommended to use a registry cleaner.
If you are encountering a slow PC, computer freezes, BSOD and other computer errors, instead of trying to manually fix your registry, download Advanced System Repair to automatically scan your system and repair registry problems in minutes. It will be able to diagnose and its optimization feature lets you pinpoint exactly how to boost system performance in no time. Go to this link to get started: http://www.registry-clean-up.net
Posted on Dec 06, 2021
Galaxy tablet ce0168 was working last week, now i cant get it to turn on. Whay can i do? Cant tel if it's charging, cables work with other devices.
Force a restart by trying t turn it on by:
?holding down the Power button and the Volume-down button at the same time for more than7 seconds.
1helpful
2answers
How to shift files from tablet to computer
To help you shift files from tablet to computer, please follow the step as given below:
- Connect the tablet to the computer using the usb cable.
- AutoPlay dialog box will appear, Click ok and then select the file or folder that needs to be moved.
- If the Auto Play dialog box doesn't open, open the Computer window then open the tab's icon.
- Locate the files you want to move from the tablet to your computer.
- Drag the File icon from the tablet to a folder on your computer or you can simply copy that files and paste it on the computer folder.
After doing this you may delete that data from the tablet to save the storage space.
GuruAid.com
How do i fix if my chrome doesnot respond and touch screen becomes impossible
Hi, you mention chrome in connection with your issue. It seems to be related to the internet only??? It might be that your tablet is not communicating with your router very well....it might be that the symptom you report has a less obvious cause.
Zeepad instructions
Please try this:
Tap on Apps in home screen - Settings - Storage - Internal Storage - Apps - Scroll down and Identify "Demo Video Application" under the apps list .
Tap on Clear Cache and tab on "Disable", Ignore the warning message.
Note: Cust may see the "Demo mode" icon in the homescreen, however it wont bringup Demo Video
My craig tablet wont start up
Try factory reset. Press the hidden reset button while powering the unit. This should clear out everything that caused the hangup.
How do i fix the Malfunction?
Go to the website for the tablet manufacturer and see if there are drivers to download for your computer.
Pavilion tx1205us Tablet PC: whay turn on tablet...
slide button to the right, the button is located on front lower left of the unit
Tablets & eReaders Logo
Top Tablets & eReaders Experts
ADMIN Canada
ADMIN Canada
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
