Question about Kenmore Refrigerators
Embarco 60HER, can't get a replacement Overload
So the overload on my Kenmore 106 series fridge went pop. Did resistance check on the start dev. and compressor, all else good. I go to replace the overload, Klixon 757NFBYY-53 and it apparently can't be found anywhere. I'm no technician, I'm just a cheapskate trying to fix my fridge. What is an alternative solution? I've read to replace with a 3 in 1, but the opinion is mixed. If so, which model? Or, can I just use another 4TM similar looking overload I assume not since I would guess they are all rated differently, but like I said, what do I know. Thanks!
Posted by Neil Campbell on
Kenmore freezer overload relay went out so i fixed it for about two days . why would it be blowing the overload relay, bad compressor maybe ??
is the relay side sensitive? installed upright? what's starting amps on compressor? verify all connections tight, obviously replace start kit first but possibly compressor going bad.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Install whirlpool starter/relay kit
you should of ordered part number 8201786 and this is the whole start device that slides onto the compressor,this replaces the overload and relay and it's around 60 dollars. http://www.searspartsdirect.com/partsdirect/part-number/8201786/0046/106?pathTaken=directMatch&filterPart=&pop=flush&prst=0&shdPart=8201786 unplug it,pop the clip off and remove the cover,slide off the device,read instructions, wire it,slide the device onto the three pins on the compressor,put the cover and clip back on and you're done.hope this helps and good luck with your machine
2answers
Replaced the overload switch on my kenmore refridge the compressor went on and some cool air started to come out of the vent in the fridge,but seconds later, no air and the compressor stop coming on. The...
HI welcome to fix ya. I would try replace the microcomputer. The part number is 2149705. Sears has them on back order when I looked up your model. This should solve your problem. I hope this helps.
Fridge question
Sounds like you mad have a bad relay or overload on the compressor. I would also check your condenser fan motor to make sure its running and blowing air on the compressor to cool it. If its not running the compressor may be overheating and shutting off on its overload. If the condenser fan motor is running I would assume that you would need a new relay and overload it will come in a kit. Usually it will make a clicking sound when the compressor is TRYING to start and then shuts off on its overload if the start components are bad.
Hope this helps _MJ_
2helpful
2answers
I had a repairman come in yesterday. Said my
12 o'clock red...4 o'clock blue...3 o'clock white .( the white , has the smaller terminal )
I have a Hotpoint RLA31 fridge which has just stopped working.
Although I feel you have checked all the fuses associated with your unit, there are other things that would keep the voltage from the compressor. When your refrigerator starts, power is applied to the start windings of the compressor via a starting relay. Once the compressor is started the relay switches to the run windings. In series of the start relay is an overload device preventing too much current draw. It may be possible that either your relay is broken, or your overload is not closing for some reason. You can buy these starting components for fairly cheap. So to answer your question, no there aren't any more fuses, but there is the overload.
Kenmore model 525321 overheat problem
hi thanks for the question after your husband replaced relay & overload if the compressor started & kept on running but no cooling you have a bad compressor
Kenmore frig will not cool
if compressor is hot that means comp- is trying to start but the relay /overload is bad allow comp to cool down unplug from wall and replace with exact type 1/2hp 1/4hp 1/3hp etc make sure all wireing is correct and unplug before starting that model may or may not have a run or start capacitor replace it also..
Refrigerators Logo
Top Kenmore Refrigerators Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Paul Carew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
