Question about Coffee Makers & Espresso Machines
Cuisinart Brew Central 14-Cup Programmable Coffeemaker's clean button won't work. Help
Has always worked in the past
Posted by Cathy Broadfoot on
ADMIN Canada
    Top Expert:
  • Coffee Maker... Master
  • 41,770 Answers
Question edited to add full maker and model.
Question from from Larry's computer category to Coffee Makers.
Try the cleaning reset
https://www.google.com/search?q=brew+central+14+cup+clean+button+wont+work
Posted on Oct 29, 2021
Filter lid spins properly, brew lights are on; but it won't brew coffee.....please help
How to Repair a Cuisinart Coffee Maker - Java Jenius
www.javajenius.com > How-To
How can I flush it if it won't brew at all? ..... The filter basket is in the proper position for the coffee to enter the filter but the ... I have a regular cuisinart coffee maker for12 cups (no grinder). ... I have the Cuisinart automatic grind and brew, model DCC490SA. .... The pot brewed a good cup of coffee but as of now it is useless.
Owned this coffee maker for 14 mos. At first you'd turn the brew switch and the brew cycle would start. Over time you'd turn the brew switch and it would take awhile. Now who knows when it will start.
Over time, Calcium will deposit on the tubes and containers which get in touch with water. Try Decalcifying with Designated Products.
Usually, you do this by diluting the product, fill up the water reservoir, and cycle on the machine, without cofee of course,
Pour out the water. It will probably look troubled.
If the water does not start percolating, just let the water reservoir stand with the decalcification product for about 30 mins. don't leave it in overnight, because these products are slightly caustic to remove the Calcium, but it could damage parts if left in the machine overnight.
Repeat the process until the water starts running faster.
don't forget to rinse with regular water. 2 Cycles rinsing should suffice.
See manual for suggested products or just use 1/4 cup of Vinegar diluted with Water. .
My Cuisinart Brew Central Coffeemaker DCC-1200 Series has quit working? Is it under warranty?
you would have to determine if you are speaking under store credit warranty, the store will replace it with recpt usually with in 30 days, etc. or manufacture warranty if you have one it is usually 90 days maybe 1 yr. if you bought with a credit card, you have additional warranty period from visa, mastercard. check your credit card for this protection
Cuisinart Brew Master 00wpc brews slowly with most water escaping as steam
Try cleaning with white vinegar, using the method described in the owner's / instruction manual.
I bought a cuisinart DCC2600 as a display model. The instructions weren't available. The only thing I can't figure out is the cleaning button. How will I know when to clean the unit and exactly how do I...
The Instruction Booklet for the Cuisinart DCC-2600 Brew Central 14-Cup Programmable Coffeemaker is available here:
http://www.cuisinart.ca/pdf/ibs/en/DCC-2600C_en.pdf
See page 9 of the booklet for Cleaning and Maintenace and use of the clean button.
I have a cuisinart coffee maker. I can set the
Unplug the coffeemaker for 20 minutes or longer - not a second less - in order to fully reset it. Then, when you plug it back in, turn the function dial to Clock again. Press and hold the HR button for a few seconds, and then set the hours. It should work now unless it got zapped, as you said.
-Tha Mp3 Doctor
3helpful
Since I cleaned our Cuisinart 12-cup Brew Central with "Dip-it"  destainer last week, it takes about 3 times longer to brew, and it steams outrageously practically the whole time.  Using the same...
Run 1/3 caraffe vinegar and 2/3 caraffe water through the machine.
Dip-It is not the best cleaner to use with this coffeemaker - stick to distilled white vinegar.
If the cleaning fails to resolve the issue, and the unit was purchased in the last 3 years, call Cuisinart and see if you are still in-warranty.
Open Questions:
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Pierre Laplante
Kolbrun...
Ross Keen
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
