Question about Kenmore Washing Machines
I have a Kenmore 70 series heavy duty top load washer. It will not engage the wash cycle, but does spin and rinse and spin again.....
jann luzuriaga
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 8 Answers
Ahhhh..... it has a depict.... try to contact its owner to return it and replace a new one....
Posted on Oct 29, 2021
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Not doing anything, making a ratchetting sound, won't wash, spin,rinse, anything
Have you checked the drum for residue that may actually prevent it to spin? try to check the cycle selector as well and try to load more clothes... keep us posted, thanks for using fixya!!
1helpful
Spin cycle does not drain water. The washer just stops when it gets to the spin cycle. The washer is a 70 series heavy duty.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Washer doesn't rinse well. Doesn't spin water out properly.
Ok.you need tro make sure that its pumping out okay...if not check the filter..then pump..
Washer will not empyy water or spin or wash on any cycle
something caught in drain pump, clamp hoses and remove pump inspect repair or replace.
2answers
How to work my washer?
the timer change by itself. You don't have to change anything.
But cold rinse only works if you have the cold water connect to the washer
Kenmore heavy duty series washer
you need a new timer. order part thru sears.
Squeaking Washer
did you remove the shipping pins pins when you installed it
Washing Machines Logo
Dale Copeland
Dale Copeland
Pieter Vleeshouwers
Pieter Vleeshouwers
