Question about Brother DCP Office Equipment & Supplies
I have Brother DCP-195 I have a machine error 50 .I have followed the correcton pattern and it is not responding ,I can not turn the machine off by the off button. Can you helpf
Posted by Malcolm Wakefield on
ray gallant
    Top Expert:
  • Brother Master
  • 73,782 Answers
Unplug it
Posted on Nov 06, 2021
2answers
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured
Clean 50 is either Dirty Encoder Stripe or broken Maintenance Unit. In first case clean thoroughly the vertical Encoder Stripe and it should work. In case 2 better exchange the machine
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured.
You need to pres Menu-Mono Start-Up Arrow 4 times in less than 2 Seconds !!! and you will be in Maintenance mode. LEDs will be flashing. Press the Up Arrow and numbers will change and press OK after the one you want to select. The number sequence is the following. 8-0 2-8-6-4 4-4-6-0 7-7 9-9
1helpful
Machine error 50
On a Brother printer Error 50 typically means that the Fuser is malfunctioning.
Turn the printer off for about 5 minutes. Then turn the printer back on and wait for about 10 minutes. If after 10 minutes the printer doe not recover, you will need to replace the fuser unit. May be more economical to replace the whole printer.
DCP 185C ERROR 50
Sir/Madam
I Suggest You To Watch Clear Error 46 Unable to Clean on Brother Printers Without Number Pad To Fix Your Brother Printer Issue,In Case You Still Having Problem Then Follow Us For On :
Brother Printer Support
Machine Error 50 in brother DCP-J125
Sir/Madam
Please Follow The Link To fix Your Brother Printer Problem Below Url Link: The LCD displays an error code number What does it mean Brother
In Case You Still Having Brother Printer Problem Then Follow Us For On : Brother Printer Support
Brother dcp 195 printe umable 4f errer
On a DCP-165c the error code 4f refers to the printhead voltage. Repair order is as follows: carriage PCB first, head/carriage unit second and the main PCB last.
34helpful
2answers
Brother dcp-165c print unable 50
how ca n i fix my brother dcp 195 c unable 50?
Error 50 afte paper jam
The following is an extract from the Brother Service Manual that covers your machine:
"Error Code 50 & 51: The purge cam switch does not come ON or OFF even after the purge cam has been driven by the specified number of pulses."
The manual lists seven different causes, best case being the need to clean part of the mechanism, the worst case being replace the whole main electronics board !
Unless you have very good skills for dismantling such a complicated machine*, your choices are take it to a Brother Service agent who will probably charge you more than a new machine, or bin it - sorry !
* If you want to have a go at dismantling it, the service manual can be bought on eBay for about £5. If you don't want to spend that much, I can supply you a .PDF file copy for £1 - just post back here and I'll sort it out.
21helpful
3answers
My printer brother DCP115C ''UNABLE TO CLEAN error code 50''
Machine error 50 is a error in Purge unit.You can't fix it by yourself and your printer need service.In most case the cost of repair is more than cost of new printer.
8helpful
2answers
Error 50 brother dcp 130 d
on my DCP 130C display appear an errore message "imp. stamp 50". This is an error message in italian language that indicate impossible to print, error 50.
Please, have you some suggestion to resolve this problem?
Thansk in advance
Ekse
k24674
