Question about Cell Phones
How do I get water out of my iPhone 12?
I dropped my phone in the water, it seems like everything is working except for the speaker. What to do?
Posted by Emily Harris on
john h
    Top Expert:
  • Cell Phones Master
  • 25,653 Answers
To dry your iPhone, tap it gently against your hand with the Lightning connector facing down to remove excess liquid. Leave your iPhone in a dry area with some airflow. Placing your iPhone in front of a fan blowing cool air directly into the Lightning connector might help the drying process. You can also try this turn off your phone let dry out a day or two encased with rice in bowl or hair drier it for awhile then then check operation
Posted on Oct 25, 2021
1helpful
IPhone 4 speaker volume is too low
The most obvious solution would be to check the volume settings either by using the volume control on the side of the phone, or through the audio settings in the settings menu. If everything is already set to high then the next thing to do would be to check for water damage/physical damage. If you look through the headphone jack you should see an indicator for water damage. If there is no liquid it is white, if there is liquid it turns red. If it is red then there could be water damage affecting your speakers, otherwise if it is white check the speakers themselves. These speakers are pretty much made of paper so anything could harm them. All in all though if everything seems to be ok, but the speakers are still low take it to your carrier or the apple store. The iPhone has a 1 yr warranty but sometimes the apple store will take care of it for you even after the 1st year.
Jul 09, 2013 • Cell Phones
Everything on my iphone works but I can't see anything the view is black
This iphone repair is rated " HARD "
Your phone is water damage and there might be multiple issues. If you can, just open the iphone and try to clean LCD connector. It seems like there is short on LCD connector and it is causing issue. If you clean it with contact cleaner your phone will work 100% fine.
if that does not work then you for sure need iphone screen replacement you can do it yourself or the best is to take to cell phone repair store and get it fixed.
2answers
Dropped Iphone, now callers cant hear me....
Check the hole inside the headphone jack. It can get clogged with lint over time and either make a bad connection if you are using headphones, or remain partially pressed from inserting headphones. Use a small paper clip to gently loosen any debris.
I cannot get any sound through headphones or internal speaker on my iphone 4 using apple remote which is paired with my home laptop windows 7 and my iphone .everything works ok except no sound when i play...
Using the apple remote app on the iPhone only changes the song on your home laptop with windows 7. To play songs through your headphones or internal speaker you have to use the iPod app that was preinstalled on your iPhone 4.
5helpful
4answers
IPhone 3G & 3GS Power Button Not Working
I have seen this happen wit a few other Iphones and the hardware parts for the power button seem to be very fragile and easily broken.
Iphone display doesn't work after it dropped
You will need to take this phone to Apple. Hopefully you have a warranty. I had the same problem once on my Iphone...It cost me 199 to replace my phone.. i had no insurance. You screen is damaged.Sorry.
1helpful
Liquid damage "5 to gallery"
sir this is a typical problem when water seeps through the phone... may be the servicer havent cleaned it up well.once again ask him to clean it up well. my advice is change the keypads... it might prove helpful.. thank u sir
Dropped in water
this happened to me for more then 3 seconds in water for the razor, turn off the phone, remove the battery and SIM card, let it sit in a dry place over night, and check again next day, it should be fully functional
Cell Phones Logo
Top Cell Phones Experts
Ekse
ADMIN Canada
ADMIN Canada
Are you a Cell Phone Expert? Answer questions, earn points and help others
