Question about Casio Office Equipment & Supplies
Casio t500 will not feed paper - Casio Office Equipment & Supplies
Posted by vince on
3answers
The paper feeder does not work. It hums and shows error.
DEBBIE LOOK IN THE OPERATORS MANUEL OR CALL CASIO CUSTOMER SUPPORT
My casio pcr-t500 isnt printing out nothing.
Make sure you use 57mm thermal paper and the shiny side must face the front
I have a casio pcr-t500 cash register I just need some help to program my tax rate.
It is in the user manual, around page E-65:
http://www.manualslib.com/download/719074/Casio-Pcr-T500.html
How to reprogram 035 on casio pcr t500?
Go to Casio Support webpage to Download Manual for your device:
http://www.casio4business.com/sa/support/downloads/downloads_manuals.html
Casio hr100tm won't print, shows E, won't feed paper. It calculates in On mode only.
mi sumadora, de repente se queda en E y no me deja seguir sumando cantidades que solucion tiene esto
2helpful
I have a borrowed Casio FR 105S printing calculator. How do I load the paper?
Make sure the paper has a straight clean edge. Feed the paper into the slot in the back - make sure the paper is straight. Paper will go in about 1/4 inch. Push the feed button and the paper should feed through the printer.
6helpful
2answers
I can not feed in paper in My HR 8TE calculator
Here are the steps for feeding the paper into Casio HR8TE calculator
First feed it through the back, then cut the paper to form a V, then feed this from the bottom and finally when you push feed it grabs the paper!
Please leave me comments, if you need further assistance
RNJ VINODKUMAR
7helpful
HOW TO INSTALL PAPER ROLL IN CASIO HR-8TM
There is a slot just in front of the printer
1. turn the power on
2. turn the switch to "PRINT" position
3. slot the paper in & press "FEED"
4. the paper should be able to feed up
Connect casio tk-t500 to PC?
Hi.
Yes, special software, special Casio cable, then training. Not recommended unless you have a need to backup or edit huge amounts of data. If you have dreams of easy data entry, it isn't always the case. I find some tasks to be much easier and quicker on the register. See a dealer if you want more info.
Mark
13helpful
2answers
I'm so stupid
  1. Remove the top gray lid of the calculator
  2. Insert paper through the back side slot near the power charger
  3. Turn the calculator on print
  4. Press FEED a couple times
Top Casio Office Equipment & Supplies Experts
k24674
Ekse
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
