Question about The Computers & Internet
Zagg Rugged Keyboard question
The 'spacebar' works just sporatically; sometimes I have to press in a number of times to get space which slows me down! I have cleaned it with air...how can I get underneath it to clean it more thoroughly! Thanks.
Posted by Trudi Neiverth on
nic_spiers
    Habit-Forming:
    New Friend:
  • 6 Answers
Try lifting the space bar off the keyboard and manually pressing the membrane. Does the space now appear? It is possible that the protrusion under the space bar is not long enough to actuate the key contacts, or has worn down. If this is the case, you may have to fashion a longer protrusion.
I had to do it to a brand new Fujutsu laptop. It was a manufacturing issue and Fujitsu were not going to re-manufacture the space bar to fix the problem.
Posted on Nov 04, 2021
  • Trudi Neiverth Nov 04, 2021
    Thank you. I am afraid that I won't be able to get the space bar back on - if I remove it. I tried with another key to see how they fit in & 2 little pieces of plastic came out with the key....Have no idea how to put this key back! So, probably best not to remove it.
1helpful
I have a zagg keyboard with my iPad. I want to know how to write paragraphs when writing an iMessage. The up and down keys do not work. When I press enter the message is sent.
Try holding down the SHIFT button and enter at the same time, that should put you down to the next line or add as many spaces as you need from your last line of texts.
1helpful
2answers
Cannot get ZAGG keyboard pair to iPad
Check that the keyboard's battery is working and it's on. Turn on Bluetooth on the iPad (Settings > Bluetooth). Press the keyboard Connect button. Choose the ZAGG Keyboard on the iPad, and type the code on the keyboard.
This doc describes the process: http://cfprod.zagg.com/downloads/ZAGGfolio%20instructions/ZAGGfolio%20instructions.pdf
Good luck! :)
Wired and onscreen keyboard space bar doesnt work
Keyboards are cheap. If you need to use this one then you will need to carefully pop the spacebar key out, turn the keyboard upside down and give it a good shake. You will see a ton of junk fall out ;)
Spacebar somewhat jammed
It seems that the button below spacebar is broken, there is a small plastic button which teared up sometime due to using the button over time time, try to replace the keybaord, you can check local shops for replacing single space key.
When i press spacebar my search results page appears
Keyboard replacement solved the problem. In my case it was a faulty Logitech keyboard. It seems that Spacebar is acting as F3 and Space the same time.
2answers
Space bar is sticky du to liquid accident ( soft
Get a Electrical/Electronic solvent spray from RS, give it a good spray (with Power Off!) and operate it lots of times. The spray will evaporate naturally and may remove the gunk! Ian.
1helpful
2answers
Pressing spacebar once will make cursor skip 3-5 spaces
I had the same problem on the Logitech MX3200 wireless keyboad. I simply unplugged my receiver from the USB port and plugged it back in. It's not the first time I've had this happen
3helpful
2answers
Letters typing very slow and repeating
Sounds like your keyboard needs a clean and some new batteries.
Mx3200 First the spacebar won't work andthenitworkstoowell.
did you check to make sure that the springs and bar under the spacebar are seated correclty?
My keyboard is inserting spaces where they don't belong.  it is usually around R's, N's and spaces (I  press the   spacebar once it it inserts 2 or three spaces, the  faster I type the   worse it gets.)...
You should open the key board.and clean space key and change rubber cap.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Computers & Internet Logo
Top The Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
EKASYS IT SERVICES
EKASYS IT SERVICES
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
