Question about Tascam Audio Players & Recorders
I have a tascam dp004 when I try to turn it on the screen will light up a light gray and nothing else works
Posted by Derrick A Spriks on
Tascam DR-05 Blank Screen
Always do the easy thing first, make sure your batteries are good and in right. You may not have the back light on. In your menu scroll down to "other", scroll over to the right. Scroll down to "system", scroll over to the right. Scroll down to "back light", over to the right then move up or down for how ever long you want the black light to stay on.
Top portion of screen has black and horizontal/vertical white lines. When I turn it on screen is dark gray and unreadable. When pushed to turn pages, lights up briefly, then goes dark gray again. Worked...
Try to hold the slide key for 15 sec. It will reboot your kindle. If black patch is not gone even after that, It's a hw issue. Screen might require to be changed. If it's in warranty Amazon will do it free. That's what i have heard.
My Tascam DR-1 digital recorder will not turn on
To initialise the Tascam DR-05:
Press and hold the + button and the Mark button while turning on.
Thanks
Screen lights up but cannot see or read anything
This issue just popped up on here a couple of weeks ago. Here is a copy of that exchange which might address your problem too:
posted by calman71 on Nov 01, 2008 screen lights up white, no picture Best Solution posted on Nov 03, 2008 3%20stars.png
BostonDave The only thing to try would be to locate the contrast knob next to the screen (near lower right of screen) and turn it to see if the picture gets better. I have the Mk1 which has a green screen, but I find that one is only visible when the contrast knob is pretty much exactly on center.
If that doesn't do it, I would begin to suspect a loose connection behind the LCD screen. You could probably remove the cover and locate the connector yourself, but depending on how old your 2488 is doing so might effect the warranty.
Cheers.
bd. Comment by calman71, posted on Nov 06, 2008 Turns out to be loose wires.Thank you for helping ,
2answers
Tascam 2488 Portastudio screen.
You could add an HGR monitor interface module to display the 2488 on a PC monitor.
www.hgr2488.co.uk
That way you don't need to look at a damaged display and the 2488 (MK1, MKII and NEO) work just like before.
Top Tascam Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
