Question about Jacuzzi Home
How to fix air lock on my bathroom jacuzzi motor
I have an ultra jet 1081 and 1795 motor and I turned on the jets one day with to low water. Ever since it makes a humming sound and the jets will not turn on. I can't find any videos or troubleshooting addressing this particular motor.
Posted by J. Carroll on
Why do jets turn on, then shut off?
the motor protection device is sensing to many amps. could be a flow restriction or the pump motor bearings are going bad.
2helpful
I've got no water coming thru the side jets in my pool, even though water is pouring through the jacuzzi jets. The jacuzzi is all part of the pool.
This is an ether or situation. Most systems now are set up with three way valves and if you turn the jets on you will shut the pool returns down. If you turn the pool back on you will shut the spa jets off.
Water coming out of adjustable air vent behind wall of tub
one or more of the jets are turned off. i would suspect someone is plugging the jets off which causes water to go backwards in the system and the water goes out the air controls. solution: check the jets to make sure the jet faces are turned on and/or tell someone to quit plugging off the jets when they are in the tub.
1helpful
My jacuzzi bathtub plastics pipes underneath are leaking due to being chewed by rats. So if i fill up the tub to the jacuzzi line holes, water leakes through the chewed pipes on to the wood floor...
no there is no solutions for plugging off the jets so the water doesn't go in them. you will have to pull the tub and repair the lines. no access panel just means you have to dig in!
6helpful
4answers
Jetted bath tub has stopped working. Motor hums
look on the back of the motor there should be a shaft that you can try to turn to spin free because something inside the pump is blocking it. rate me if this is helpful.
2answers
Jacuzzi jets not pumping out water
Check the jet pump, also where the filter is there are two 90s plastic. make sure that they are both in the water, if all those check out then check the switch for the jets. It sounds like the pump is bad and is not pumping the water. Even if the motor works and the internal parts of the motor seal gets wet then it all needs to be replaced and rebuilt. Very easy to do yourself. Like always be careful and unplug the unit.
Feb 11, 2009 • Home
Some of jet points inside jacuzzi are not mixing air with water
the jet are pushed by the impeller (it's like a fan blade) run by a moter water is pushed through the plumbing and out the jet head . when you open an air valve air is mixed in .
Feb 03, 2009 • Pool & Spa
2answers
Jacuzzi jet pump doesn't produce much bubbles
you need to turn the air on should be some sort of cap or screw in type thing to let the air in open it
Jan 17, 2009 • Pool & Spa
Home Logo
Top Jacuzzi Home Experts
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
