Scepter x50 tv not resetting - Televison & Video
Posted by Jodi jones on
Larry
  • Televison & ... Master
  • 3,598 Answers
A lot of scepter sets had LED backlight issues, chances are it's not worth fixing
Posted on Oct 29, 2021
We have a 2 yr old scepter tv were getting sound but no picture. Is there a factory reset we can try or is it trash?
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
1helpful
2answers
Dell Axim X50 PDA won't turn on
try a hard reset
Dell Axim x50 / x50v / x51 / x51v:
Make sure the device is on before performing hard reset. To hard reset, press and hold the power button and press in on the reset button (reset hole) on the back of the unit for about 2-3 seconds. Release both buttons and you will see a confirmation screen asking you if you would like to clear all data in memory. To do so press the Contacts button. To cancel press the Mail button.
IT may be that the mainboard is faulty and would need to be replaced.
Is there a reset for a scepter tv
My Scepter X32 TV screen got smaller, I was watching HD tv and everything was fitting onto the screen. Then I moved the TV a little bit and it changed to not fitting everything. Any idea how to fix?
Do a reset to this TV and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Switching from analog to digital on scepter x50 hdtv
All the new flat screen TV's work on a digital signal only. There is no switching from analog to digital anymore. The signal from an antenna is digital now too. There are no analog signals anymore.
1helpful
Samsung HT-X50. I just installed a new 50" plasma TV and cabled the digital out to the Samsung HT-X50 digital in via an optical cable. The TV audio is now heard through the HT-X50 speakers but only...
Look into the TV's audio controls. If it was my setup, I'd NOT send audio through the TV to the hifi, nor video through the hifi to the TV. Additional hops and interconnects cause problems even though they're theoretically transparent.
5helpful
Scepter X32 LCD High Definition telivision. Just
Yes it's dead; the power supply in these tvs do not have much stamina;
Due to the fact that their are no provisions for removal of heat. TV does not
have enough fans because customers don't like the noise and, the power supply surge caused by turning a cold set on and, off is not addressed by the manufacturer.
That is why the sets have only one a year warranty.
The choice you have is: repair the power supply or, replace the power supply
unless your set is under warranty.
1helpful
Axim x50, buttons all work, syncs without a problem but sometimes freezes
You might need to hard reset it or update your Dell Axim x50
it is important to know if you have an x50 or a x50v. here are two vids. first one is for x50, x51. second one is for x50v, x51v.
Dell Axim x50, x51
http://www.youtube.com/watch?v=9K2P_SNTuGo
Dell Axim x50v, x51v
http://www.youtube.com/watch?v=vEDvCklrNs0&feature=fvw
2helpful
2answers
Had the same problem. Did some research and fixed the problem by performing a "soft reset". Tap the reset indentation on the back once quickly. Do NOT hold it in or you will lose all saved data. Mine's working fine now.
2answers
PS2 problem
the daual chock did not work
Televison & Video Logo
Top Televison & Video Experts
Ekse
