Question about Mitsubishi Office Equipment & Supplies
I have a 73 mitsubishi DLP model WD - 73742 theirs almost gone so darkpic
What do I need the status light still flashing.
Posted by Thomas Fluker on
Lamp status flashing orangey red
Your lamp door switch isnt activated. either the door isnt secure or the wire isnt plugged in. Flashing orangy red LED means just that.
Mitsubishi wd-73c9 status light blinking orange won't turn on
may need the lamp replaced pt# 915B403001
Recommend Phillips, OSRAM or Mitsubishi original (as from experience others will not work or will have very short life)
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73C9
I have a blinking yellow status light on my mitsubishi 73837
blinking yellow indicates no lamp or the lamp door is open. if you had the back off you may have gotten the door switch aligned improperly. the door switch is located just inside the lamp door.
the lamp may also be bad.
lamp part# 915B403001
see website:
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73837
Mitsubishi wd-73c9 73" dlp tv
Here's what the Manual says about light codes for this TV. See Picture of actual page from manual.
The status light on a wd-73838 and a wd-65838 keeps flashing
the problem on this tv is the dm pcb , not the dmd , or may i say main signal board , also u can open the tv and chack for bad capacitors but if there is not bad capacitor you would need to replace the main pcb
I am having issue with my TV it won't turn on and I have a flashing red status light keep flashing can anyone help
Hi, if your tv is between 1-4 yrs old and havent replaced the lamp it might be time to do so.Mitsubishis uses Osram lamps to light up the screen and tend to last from 3000-4000 hrs normally 1-3 yrs.The Red light indicator usually indicates its time to replace the lamp.Heres the lamp you would need http://www.discount-merchant.com/Mitsubhishi-915P027010-915P027A10-Replacement-p/mitsubishi-915p027010-lamp.htm?1=1&CartID=0 On the same link it shows you how to replace it ,have a blessed day.
Top Mitsubishi Office Equipment & Supplies Experts
Ekse
Jean Sintulaire
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
