Question about Thermador Refrigerators
Water and ice control panel not working
Side by side Thermador fridge and freezer (column?) the water and ice dispenser not working, like totally dead no led light or anything
Posted by Kenneth OTT on
jann luzuriaga
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 8 Answers
Ahhhh... for me, it is a bad appliances and need to check ( if it is new, you have to return it to the owner and replace a new one) to the technical experts.... if you want to...
Posted on Oct 29, 2021
1helpful
3answers
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Control panel off lights in fridge and freezer on but not working
Unfortunately the control panel is probably defective. But check for power to the panel. This controls the temp of the freezer, fridge and the solenoid control valves for the water and ice maker. What is the Year, Model and Make of the refrigerator?
2helpful
I own a Thermador Freedom Collection 18 inch Built-in Freezer Column with Exterior Ice and Water Dispenser Model T18ID80NRP and have had this unit for approx. 2 years as a companion unit to my Thermador...
No solution but just a warning. We had this same thing happen. They sent a repairman to replace the control board. Then did it again. Just before Christmas, the WATER started dispensing by itself. Luckily, I was nearby and heard it or the damage would have been extensive from flooding. They are now 'working on' getting a response from Thermador. I feel like this thing is just a homeowners claim waiting to happen.
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
10helpful
3answers
Ice/Water dispenser not working correctly
hi,,
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
13helpful
4answers
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
1helpful
No lights or ice/water available
go here and get a new manuel for free if futher assistance is required reply to me yes its a good site http://www.maytag.com/support/manuals_literature.jsp
4helpful
2answers
Ice/water dispenser control panel
could be the dispenser board or the main board. hard to sort out without a meter. most likely the dispenser board but i have seen a dispenser board go bad and smoke the main board if that is the case you can damage the new component so check out the cost on the parts
Refrigerators Logo
Top Thermador Refrigerators Experts
Ekse
ray gallant
Tom Chichester
Are you a Thermador Refrigerator Expert? Answer questions, earn points and help others
