Question about The Computers & Internet
I need a part for a Venmar range hood, the manufacturer is out of stock. The hood was made in 2002, and I have both model and part number. Is there a supplier out there who might have it?
The model is a Connaiseur, model # CCM1430W, part# 04249.
Posted by Rick Odegaard on
  • 2 more comments
  • Anonymous Oct 21, 2021
    learn google
    and ebay
    and amazon
    search by model range and part # needed and is off topic here, so why to that?
    post to ranges
    not in computer repair help.
    https://www.fixya.com/troubleshoot/brows...
    it is NOT any kind of computer,
    or reload windows 10 and reboot the RANGE.
  • Rick Odegaard Oct 21, 2021
    Thanks anonymous....did all that and fortunately didn't find the part. I say fortunately because it turns out it was simply one half of the slider's plastic grab bar on the internal switch that had snapped off inside, ergo unable to move the hidden switch. I have simply removed the plastic slider and can now turn the light on and off as needed by reaching into the hole.
  • Anonymous Oct 22, 2021
    ok, new mfg parts not sold leaves what USED and NOS, new old stock
    only goolging that finds that, using the web,.
    finding used parts is a matter of pure luck and or hard work, you will not call 10,000 appliance repair shops on earth for that, nobody does that. leaving (your shops, google, ebay and amazon)
    and now is bypassed, end story and 100% off topic here as it is NOT A COMPUTER
    if you learn to post to ranges above, LINK. RANGE.
    who knows someone might have parts in stock but NOT here in computers we have no ranges at all
    zero. no parts. and off topic.
    why post to wrong forum?
  • Anonymous Oct 23, 2021
    post top RANGES
    not to COMPUTERS
john h
    Top Expert:
  • The Master
  • 25,748 Answers
`do an online search or an appliance repair shop in your area
Posted on Oct 22, 2021
How to replace control switches for a venmar hood fan
[PDF]Download - Venmar
www.venmar.ca/DATA/.../131_5_en~v~Installation_Manual.pdf
Before servicing or cleaning unit, switch power off at ... solid-state speed controldevice. 8. ... should not be allowed to accumulate on fan, filters or in .... We recommend to install the hood at a minimum distance of 24" from an electric range and.
FAQ - Venmar
www.venmar.ca/en-faq.html
Can I use other controls than Venmar controls with my unit? What is the ... Range Hoods. Can I replace an "over-the-range" microwave with a range hood? ... VenmarConnaisseur C270 and C600M · Rocker switch control. Venmar V10 ...
Range Vent Hood Switch Parts In Stock from RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Range-Vent-Hood-Switch-Parts
Shop for your Range Vent Hood Switch from our huge inventory. Check our ... RepairHelp for Range Vent Hoods ..... Blower variable speed control switch.
Range Vent Hood Repair Help - Free troubleshooting
Change a lightbulb(won't budge) in a venmar 430 or 330 range hood
Get a new bulb and look at it, that will help as not all bulbs have the same base.
Why won`t the fan of my venmar range hood turn off?
Sounds like you may need to replace the fan switch. The fact that it wont turn off and that it only works on low speed supports that switch is broken.
The light diffuser cover is broken. The model number of the range hood is HO60488. The range hood dates back to possibly the late 1950's when the house was built.
When faced with the total unavailability of replacement parts, its time to get creative, and make your own diffuser cover. Flat ones
can be easily made - find anything plastic that's semi-translucent (like a plastic milk bottle), and cut it with a utility knife.
I have also used a utility knife to cut a polystyrene diffuser cover
originally intended for a 2-ft x 4-ft suspended ceiling fluorescent light fixture.
In case the diffuser cover you make wants to burn when placed close to a light bulb, replace the bulb with a CFL (compact fluorescent) bulb, which run MUCH cooler than incandescent light bulbs.
Old lampshades can be cut and used, but may need to be ironed flat. The major advantage of lampshade material is that
it can be folded over at the edge once or twice, which will fill space - and possibly hold the cover where a plastic sheet might be too loose.
You'll know that your efforts have met with success when you can easily remove your ne diffuser cover to replace the light bulb.
I do not know the model of the Venmar range hood that I have, but it needs new filters. Is the model number stamped or printed on the unit anywhere?
yes, inside top front cornerusually or if you have your old filter , take to homedeot or lowesand if nothing else, you can cut one to fit with a pair of kitchen shears. thanks karl
20helpful
2answers
Venmar stove hood, plastic cover for light is broken
Need plastic cover on Venmar vent Hood, which measures 3 1/2 inches by 18 inches with 2 tabs.
We canot find a part: the plastic cover the light bulbs
Try universal Appliance parts store..google it for a location in your area...
Electronic Control Not Working
The electronic controller is faulty. You will have to contact the supplier where you purchased the rangehood from to find out who the warranty agents are for that make & model.
Computers & Internet Logo
Top The Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
Axel Gringmuth
EKASYS IT SERVICES
EKASYS IT SERVICES
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
