Hi, we are looking for a manual- installation and running for a Selkirk gravity direct vent wall furnace FDV35-3100 please help!
Posted by lisa on
2answers
3509622 model number furnace heats up but does not blow any air out. Neither hot or cold air.
You are describing a Convection heater , they do not have any fans inside.
Williams direct-vent wall furnace gas pipes instalation process
There is only 1 way and that is inside the unit, How would your gas line end up outside the wall ?
I suggest you have someone who has experience do this for your safety.
Cracked Selkirk METALBESTOS gas vent pipe on 80% efficiency furnace (Trane XE80)
I would check with a local furnace company that installs Tranes and ask if they sell to the public, if so buy it.
1helpful
It is a Williams circa 1985 gravity direct vent wall furnace mdel 30DV 5, 30,000 btu. Light pilot OK. Heat on OK. But when heat not called for (several hours) pilot must go out. There is a small penny...
That hole should only be a problem, if a strong draft comes thru and blows the pilot out. But that hole may also be for match lighting the pilot in an emergency. The older models like yours, had that feature. Check it closely, before you decide to block off the hole.
Hope this helped you.
Empire furnace Model # GWT-35-2 seriel # 0614425864. I had a furnance repairman replace the to snap switch. Still have the same problem at times. Furnace will not start unless snap swich is pressed.
As an Empire Comfort Systems dealer, I'm not quite sure what your mean by "snap switch"?
It certainly isn't anything that's listed in the parts manual for your gravity vented furnace.
Your furnace is equipped with a manual "reset vent safety switch."
The manual reset vent safety switch will cause gas flow to the main
burner to "shut off" due to improper venting or a blocked flue.
Is this what your serviceman replaced? Since then have you or anyone checked to see is vent pipe is clogged or is improperly venting?
If the manual reset vent safety switch continues to "shut off" the gas
flow to the main burner. A qualified service person must be contacted
to inspect for improper venting, blockage in the vent pipe or the
manual reset vent safety switch for being defective.
Hope this helped to head you in right direction.
1helpful
Is it ok to install flue for 95% furnace out of side wall
YES, that why the power vent fan motor is there and it,s not gravity fed!
Williams gravity vented wall furnance - where is the pilot?
Its in the bottom of the heater behind the vent cover . I don't know where you are but your local gas utility will come out and lite this for free.
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
john h
