Computers & Internet Logo
w
wagdighattas Posted on Oct 20, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the latest firmware to my Toshiba 385p"305s if any one can help I'll be so grateful to him
  • goneforever. Dec 31, 2021
    Hi wagdighattas , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    DON'T do not.
    ask them only not on social networks
    or you will brick that super old business size grade printer monster.
ADMIN Eric
Level 3:
Top Expert:
  • Toshiba Master 39,345 Answers
  • Posted on Oct 21, 2021
ADMIN Eric
Toshiba Master
Level 3:
Top Expert:
Answers
39345
Questions
0
Helped
794405
Points
588034
The correct firmware is only available from the manufacturer.
Go to toshiba.com, find your model number and download the latest firmware.
  • 4 more comments
  • Anonymous Dec 09, 2021
    TOSHIBA e-STUDIO305CS/305CP/385S/385P/525P
    a printer? or computer,???
    the L385 is printer series.
    e-studio means printer.
    not told.
    ask the maker for firmware, no there, ask them and they must match it up EXACTLY to your unstated
    product service tag data not told.
    and to version and country
    and to even the serial number (and HW version code)
    only available not infected from Toshiba.com
  • Anonymous Dec 10, 2021
    leave it alone.
    best is post a real problem
    or ask maker directly for help with problem lord knows, these printers are nothing but problems for 40 years.
    endless.
    if you march down that track you will make it worse. i promise, for sure off hacking sites or lairs, offering it.
  • Anonymous Dec 20, 2021
    not told why , there needs to be a legit reason
    or you will brick this PC, I promise.
    flashing for kicks is not wise.
    flashing PC/printer that is sick it will brick.
    it ran of ages ok and eeproms do not forget.
    they have 200 year retention spec.
    battery 1 year if abuses
    your model number posted is a wreck why>?
    but is old printer sure
    talk to toshiba direct and not brick it.
    The e-STUDIO305CS/305CP/385S/385P/525P products
    which one? is it. >> it is series but is only one model.
    here they are,https://business.toshiba.com/support/#do...
    ask them.
  • Anonymous Dec 27, 2021
    ask maker for help,
    do not flash it until they tell you to.
    period.
1helpful
Studio 385p toshiba printer jams out on printing double side
Clean the rollers behind the door on the back of the printer. These are the ones that turn the document over.
@ALL, PLZ AM NEW TO THIS FORUM, I HAVE A CHALLENGE WITH MY KODAK EASYSHARE Z1285 CAMERA. I WANT TO UPDATE THE FIRMWARE FROM 1.000 TO LATEST VERSION. I WILL GRATEFUL IF ONE CAN PROVIDE A LINK FOR T
The firmware is at the Kodak website listed under support and downloads, Be sure to get the file for the Z1285 camera and not a wrong one !!! Go to www. kodak.com and click support.
Best Regards, Russell
How to bypass setup password on a toshiba satellite A105-S4074
You can fix this by removing first removing all power, then remove the plastic cover above the keyboard, removing removing the two keyboard screws.
You'll need to fold the keyboard in such a way that you don't damage the cable.
You will see the wifi card just to the right. It's the only card there. It is held in place by spring clips. Remove the card from the connector.
There are two solder contact points labeled "C88". Connect the power adapter to the laptop now. Short the two contact of "C88" and press the power on button. The unit should boot to the windows screen. Once it boots, you'll have to update to the latest BIOS.
There is a problem with the printer head
A firmware update will help resolve the problem that you're experiencing. Just go to http://bit.ly/ghfW8H to download the firmware update. Before applying the firmware update, you'll need to get rid of the error message. Just remove the printhead and close the cover of the printer then press cancel. Once the error message is gone you can then proceed with the firmware update.
If the problem persist after the firmware update. You'll have to call Lexmark's technical support.
1helpful
Need owners manual for a Sub-Zero 695 and maintenance manual
If your trying to remove the grill plate thats located at the top of the machine what you need to do is open both the freezer and the refridgerator doors and look up. There are three vertical phillips head screws that you'll need to remove first. After that you'll be able to pull the grate forward and remove the springs, one on each side that keeps tension on the grate. Once those are removed, the grate will be easy to take off.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
It finishes down loading up dates then e 66 pops up
I'm going to make a few assumptions in my solution, based on the nature of the problem you're having. First, I'm positive you're talking about an Xbox 360 console, but I'm going to infer that it's an older model without the HDMI port. Next, I'm guessing your console has a Toshiba/Samsung drive, which is the most common drive in older units. And finally, because 99% of the time this issue occurs in modified consoles, I'm pretty sure your drive has been flashed with an alternative firmware. Assuming these assumptions are true, you need to flash your drive with the original firmware. Given the nature of this particular topic, I won't go into detail on how to do that, but a couple minutes on Google will tell be more than sufficient to find that information. Once your original firmware has been restored, the update will complete successfully and you can reflash your drive with the modified firmware of choice. The problem occurs because the latest update flashes the drive with Microsoft's new firmware to allow consoles to play games using the new GDX3 media. On Toshiba/Samsung drives, the update checks the drive's firmware and doesn't recognize it as the original firmware, causing the update to fail and report an E66 hardware failure error.
My 3gs not able to power up on it's own. have to plug in to on freeze each time.
There may be some firmware corruption. Try to restore your device.
To restore:
1. Connect your device to your pc
2. Launch Itunes. Itunes should pick up your device
You may need to update the itunes version to latest one.
3. Press restore and follow onscreen instruction.
It'll take a little while so please be patient.
Hope this helps.
Regards
3helpful
2answers
Blackberry 8520 curve was reset app 523 error what i do
Connect to the Desktop Manager. If your device still having problems. Wipe it with BBSAK. Then insatll software from Loader application.
1helpful
3answers
Toshiba estudio35 trouble code
I have a toshiba estudio35 copier I CANAT INSTALL IP\TCP IN MY MACHIN
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
