Question about Vtech Lands Phones
Why does my vtech phone model cs6829-2 always disconnect all calls after 29-31 minutes?
It never fails when a call reaches somewhere between 29 to 31 minutes, the call just ends. It doesn't matter if I initiated the call or if someone called me. It could be 29:54 sec or 30:15 sec - it's different all the time. I then have to call them back but sometimes I have to wait a few minutes to do so because I don't always have a dial tone. The service provider claims it has nothing to do with their service. I've never heard of this problem before and never had it happen on past vtech phones I had.
Posted by Cheryl Wilson on
  • The Spaminator
    The Spaminator Oct 21, 2021
    Hi Cheryl Wilson, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    Is the phone plugged into a phone line ?
    Is the phone line solely used for Analogue phone use ?
    Or is phone line being used for a digital syncronous line (DSL) data service as well as voice phone.?
    Is phone a voip phone (voice over data) ?
    if voip what router or network switches are involved ?
Phone onlt rings three times
What model VTech phone? Are the calls going to an answering machine or a voicemail system after three rings, or are they getting disconnected?
My Vtech cs5121 cordless phone has no dial tone
Vtech phones are junk! I have had many trouble calls for no dial tone,only to find out the Vtech phone is the only one they have,and it is defective.(It really DOES pain me to bill someone 91 dollars to tell them their 21 dollar phone is broken-always try another(preferably hard-wired) phone before calling the phone company!
My handset says is in use and phone will not let me call out.
Try disconnecting the phone line and power from the main base and waiting about 2 minutes. The reconnect everything. Should fix your issue.
8helpful
My phone dials too fast. The only way I can dial a number is by taking it off the hook and manually dialing after I hear the dial tone. If I use Caller ID, redial, directory, or putting in the number...
I had the same problem with a model 6325-4. Worked fine for the first week. Then, tone dial with redial, directory, etc was too fast for system to register the number.
Called Vtech support. After a 15 hold, 5 minute explanation and tech listening to a reproduction of problem over the phone, she asked that I perform a complete system reset (I called via my cell).
I unplugged power from base first, then removed battery from all hand sets. Powered down for ~3 minutes (with tech waiting on line the entire time).
I powered up base first and then reconnected all handsets. Selected a handset at random and performed the same dial from directory test I had done just before power down. The thing worked again. Call went through just fine. Tried several other selections in directory with same positive results. Now, if the system just stays stable and working.
Hope this helps..
Phone will not hold a charge and there is static on phone
Those phones always have problems. Call the manufacturer and have them replace the problem phone(s).
Vtech cordless phone appears to be mute
does anyone out there have a solution for peggy's problem? I have the same problem------Bob
Set-up 4 v-tech answering machine
Since you neglected to specify the model of your VTech 5.8GHz cordless system I can only suggest you enter it into the search box here to download the manual.
1helpful
Vtech 9127, display bad
my vtech 5.8 GHz disconnects while I am talking~replaced batteries and charges the phones for 24 hours. I cold talk 10 minutes during this time 4x I could hear the other person~they could not hear me and then disconnect.
Characters and numbers are choppy too Thank you
Lands Phones Logo
Top Vtech Lands Phones Experts
Ekse
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
