Question about Lands Phones
KX-TA824 Display works but it displays gibberish.
I have two systems, both doing the same thing. Extensions flash. SKRZYNKA PEKNA
Posted by Bill McGurgan on
I want to turn off the beeping when i place someone one hold
The beeping when someone is on hold comes from the main control box, not from the phone itself. You must be able to enter the Panasonic system's programming mode from a display phone connected to Jack 1 which is usually extension 101 in both the older 624 system and the newer 824 system. The Programming Code is "111" and this is covered in the KX-TA824 "Programming Manual" Version 3.0 on page 27. The two choices are "External" and "Tone," and you want "External" which deactivates the beeping tone and activates the miniature (3.5mm) phone jack on the control box for incoming audio (Music on Hold: "MOH"). By selecting "External," hold will be silent (no beeps) unless you connect an audio source to the jack. Entering the programming mode is covered on Page 15.
1helpful
Will a panasonic KX-T7636 work with my ta824?
No. An 824 is analog and the 76xx is digital that works only on the TDA/TDE/NCP systems.
Older analog phones (70xx,71xx,73xx and 75xx) will work, and possibly some of the old 616 and 1232 sets, as well as a 308xx 3-line set.
Carl
1helpful
2helpful
Hello friends from FIXYA, I have a situation where I cannot get my Panasonic KX-TA824 pbx to answer incoming call at the fist ring using DISA. I have tried everything and I cannot get it to work. DISA...
And??? What's the problem? My DISA is set for 1s on the first page and it never rings a phone. If you want it to answer the outside line on the first ring, you'll have to turn OFF Caller-ID. Now it will answer right after the first ring, but you lose CID logging.
On my working system, the DISA 6.1 section is with AA and 1 second, and 6.2 the first two timers are 3 and 5 seconds. In 9.1 you can uncheck CID but I don't recommend it.
Carl
1helpful
Installed a voice mail module card KX-TA82492 on a Panasonic KX-TA824 phone system and does not seem to be working at all after going through the install procedures that came with unit ?
O.K. I'll play. Did you program it to answer in 414-416? Did you record a message in BV 01? In the Features? manual 1.1.8 there are specific examples and instructions to make it work. It can be reached from the help files on the BV tab of the Maintenance console.
How do you program ring length on a panasonic Kx-ta824 system via a panasonic phone model kx-t7735?
The length of the ring is fixed, the time before it forwards is programmed in 5 second increments in System program 202. Since it's defaulted to 15 and the maximum is 20, there's not a whole lot to work with.
Carl
1helpful
KX-TA824 Select idle CO line
No. C.O. Line group access is always from high to low. However, you can turn off CO 5&6. In programming command 400.
Carl
I am unable to clear the call log KX-TA824
You have an INTERCOM button on the phone and you're probably using idle line select on pickup.
Don't pick up the handset, push the intercom button and dial your codes.
Carl
Lands Phones Logo
Top Lands Phones Experts
Ekse
Oloyede Monsuru
Are you a Lands Phone Expert? Answer questions, earn points and help others
