Question about Ovens
How to replace brackets to hold glass together on oven door
Which position do brackets go when putting glass door and inner glass together
Posted by Kenneth Bell on
1helpful
How do I reinstall oven door glass?
It depends on the make & model. But generally speaking you need to support the door in the open position. You should then be able to see the screws which hold the door components sandwiched together. These must be removed. You should then be able to remove the inner door panel. This will expose the inside of the door. The glass is now accessible.
Aug 09, 2015 • Ovens
How do I clean between the glass?
Hello Alison;
My name is Peter. I am a retired field service appliance technician.
This is a bit of a task.
1.) Remove the oven door - Put the door in the first locking position (Opened partly at the top) Pull straight up. When replacing the oven door make sure the door hinges are in the same first open position.
2.) Lay the door face down on the floor.
3.) Remove the back panel. You may have torque screws requiring a special screw driver.
4.) Remove the door latch assembly. But first take a picture of the latch so you can reassembly properly.
5.) Remove the oven glass retaining brackets/plates.
6.) Remove the inner glass.
When you are doing this task make sure you lay out the parts in the order in which they were removed for re-assembly.
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
10helpful
The inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
4helpful
2answers
Can't put door glass back in Whirlpool RF396LXE2 range
The answer is not as hard as it seems. I just tried for 10 minutes unsuccessfully to put the glass back in the two side tracks. Well the glass actually goes in front of them, the top holds the glass in place.
1helpful
Broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
2helpful
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
Part here: _.gif PS2087058
Smeg se336ss 5 some so and so has broken the outer glass door!
We removed the front glass of our oven door after a big spill between the two glass sections (by blunt force!). Since it took us 4 hours to put back together, we wanted to spread the info in case any others have the misfortune to make this mistake! Note, I wouldn't do this unless you have to, just incase you can't get your door back together again.
Assuming the back sheet of oven glass is still in position, but the front sheet is not attached -
1. Follow the manual instructions to remove the door, ensuring that both hinges are locked fully (otherwise you won't be able to get the door back on easily)
2. Once the door is removed, ensure that the plastic spacers that hold the two sheets of glass apart are in original position, resting on the inner door, at the bottom corners of the tempered glass
3. Remove the narrow metal strip at the bottom of the inner door by unscrewing the 3 screws that hold it in place. This is the metal groove that the outer pane of glass needs to rest in
4. Lay the outer sheet of glass in position in this metal strip
5. Lay the outer sheet of glass over the inner door. Slot the outer sheet into position at the top of the inner door first, ensuring it is layed flush at the top.
6. A second person needs to ease the metal strip back into place at the bottom of the inner door, so that the two sheets of glass are now held together at both top and bottom.
7. Screw the metal strip back into position with the 3 screws
8. Follow the manual instructions to replace the door. Ensure that the small grooves at the bottom of both hinges are resting in position correctly, otherwise the door will not close flushly.
1helpful
2answers
Remove Outer Glass Of Oven Door
On my Zanussi ZDF 866 it goes like this:-
Rest the door with its top edge on your work surface. Once the bottom two screws are removed, pull the outer glass away from the bottom edge of the door just enough so that the brackets fixed to the outer glass (into which those two screws went) clear the bottom edge of the door. Then pull the outer glass up towards you parallel to the door (there are now screws hoplding the top edge on this model).
It may need one side to be pulled and then the other to release it from the metal slot at the bottom.
I would recommend great care with this given that a) your door may be different, b) it could be held more tightly and c) you are dealing with glass. Recommend taking all precautions including eye protection and suitable gloves. Proceed slowly and carefully (this did not need much force on my door). If you're not sure at any stage, choose discretion and either give up or pay someone to do the job to avoid paying for a new glass or hurting yourself.
Hope this may help someone.
Jan 25, 2008 • Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
