How do I turn off writing when sound bar is on
It's got line in going across sound bar and it's distracting
Posted by Michael on
Larry
  • Televison & ... Master
  • 3,587 Answers
Can't say I've ever heard of this issue
Posted on Oct 21, 2021
How do I dim green light on my sound bar ?
If you cant dim the light I'd suggest putting a small piece of black electricians tape over the light (Depending on what colour the sound bar is) and hopefully this will stop the distraction
Nick
There are about 10-15 small lines on the top of the screen that go horizontally all the way across. These lines distort the picture up there and it is very distracting...any ideas?
The problem is in the vertical section of the TV. Usually one of the electrolytic caps has gone bad. Easy job if youre experienced with board level component replacement.
A shop should charge under $100 to fix.
1helpful
Thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Comcast Causing Purple/Green Hum Bars
this is normally caused by voltage on the coaxial cable which simply can be solve by a surge protector with a cable in and out.. but this is just a way to passify the issue. More than likely there is a bad ground either in your house or on the comcast line
Version 9.0 Grey bar acroos fourth line of invoice.
Check your options & custom settings If that doesn't fix you up, try reinstalling the program. It sounds like one of the functions didn;t load in properly.
Philips 50PFP5332D
I have sound but no picture. At first, there was picture but a lot of red lines running up and down as well as across. There were also two bars in the middle of the screen. I turned it off for a while and let it cool down but when I turned it on there was no sound at all. Do I need to have philips replace it? It's under warranty
Samsung LN-T4065F Dotted lines across screen
tell the idiots where u bought this tv from and demaand a more expensive and better tv on their bill
Horizontal lines on Screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Stripes on my Samsung Monitor
The contrast may be to high.
Adjust the brightness and contrast to make it go away but still readable.
if that does not help the FL (backlight) is going and the unit will need to be replaced.
Sorry.
Televison & Video Logo
Top Televison & Video Experts
Ekse
