Question about True TWT-72 3 Door Worktop Refrigerator
TWT 72 3 door fridge. Why isn't it getting cold?
Replaced temperature control
Posted by Bill Szentadorjany on
  • Ngoro Oct 19, 2021
    Compressor starts and runs?
jann luzuriaga
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 8 Answers
Yeah, if the compressor is not running, maybe you can replace it another one by returning your ref in the owner ( if it is a new one)
Posted on Oct 29, 2021
Temperature control panel
CHECK THE ON/OFF SWITCH ON THE INSIDE.
2answers
Hi, I have a kenmore coldspot 106.56152500 and the fridge has stopped working. I can hear it running but it is not cooling at all. The freezer is still working, however, not as cold as it should be. I...
Yes the most likely reason for not defrosting is your=> W10135901 Defrost Control Board
The defrost control board can be found inside the fresh food compartment behind the control panel where you adjust temperatures for the refrigerator and freezer. To gt to the control board you need to unplug the refrigerator and disassemble the control panel. Look over the control board sometimes you may see signs of heat damage but not always. If you have questions I will be here so please ask, Thanks Sea Breeze
106.56152500 Parts
1helpful
Nt side by side fridge freezer not freezing
If the machine is running all the time a few things could be happening, The defrost timer could be bad, but if that is the case then you should see a build up of ice forming on the wall that covers the evaporator coils. Another situation is that your machine is low on freon and not reaching a temperature cold enough for the temperature control to shut the machine off. Third and last the temperature control itself could be bad and thinks the machine isn't cold enough. in that situation you would notice ice build up as well. Hopefully this helps.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
6helpful
I have a Norcold n611 fridge gets too cold and freezes even on lowest setting.
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced.
2answers
Frigidaire FRS26R2AW5 Refrigerator too cold on fridge side.
If the dampers are closing when you select warmer temp with the fridge temp control, there really isn't a way for the cold air to enter the fridge. Check to make sure the damper isn't opening back up after a while.
My lg fridge lrbn20514bk the thermastat is not working on the top control but for freezer is reading 567
This fridge LRBN20514BK with bottom freezer is a piece of junk. Just had the relay on compressor replaced and now the thermostat isn\'t working. Temperature on fridge reads nothing and freezer temperature reading 5,6,7. Then the freezer coils freeze up and no air blowing to the fridge. Ready to take this POS outside and blow it up. Only 7 years old and never ending issues. I will never buy LG again. EVER! LNG - Life is not good! HELP.....so what needs replacing? Thermostat? And of course I have to have repair man come in due to LG not selling parts to customers. Again I call BS
Freezer is good. Fridge is not cold enough. It is on 7. MTF2195
Refrigeration half of fridge does not have a cooling unit. It gets its cold from the freezer. There is a door between the fridge and the freezer which is controlled by the fridge temperature control knob. Often times the connection is purely mechanical. There may also be a fan to push the air through the door which is controlled by the fridge temperature knob which is actually a thermostat.
Temperature not working
Before replacing the refrigerator's temperature controls, you should do some basic troubleshooting to make sure the problem stems from a defective control and not some other problem. The most obvious thing to check is that the refrigerator is plugged in and receiving power from the outlet. If it is running, but not cooling, it could be due to dirty condenser coils or a defective door seal. Once the coils are clean and the door seal has been checked, you can be pretty confident that the problem is the temperature controls.
There are usually two control knobs, one that controls the temperature of the freezer and one that controls the refrigerator. Although they appear to be independent controls, it is important to understand that the cold air comes solely from the freezer area into the refrigerator compartment. The freezer control determines how much cold air the condenser produces while the refrigerator control adjusts the flow of cold air from the freezer to the refrigerator compartment. If there is no cold air on either side, it is probably the freezer control that is at fault. The procedure to replace the control switch is the same for the refrigerator control and for the freezer control.
Even though we have gone through this troubleshooting, it is still a good idea to test the control mechanism before replacing it. You will need a multitester and possibly needle-nose pliers and a screwdriver for the testing. First, unplug the refrigerator so you don't get shocked. Then, remove the temperature control's dial and/or housing. The dial will just pull straight off, but the housing may have screws holding it in place. After removing the housing, just let it hang by its wires. There should be two wires attached to the control. Label them before disconnecting so it is easier to put back together. Remove the wires by pulling on the slip-on connectors, not the wires themselves. Needle-nose pliers may be needed to remove these connectors from the terminals, especially if the refrigerator is old.
Set the ohms setting on your multitester to X1 and attach one probe to each terminal. Turn the temperature control to off or to the warmest setting if there is no off position. The multitester should give you a reading of infinity if the control is on off and a reading of near infinity if there is no off position. Then turn the control to the coldest setting and retest. Now, the multitester should give you a reading of zero. If both of these tests are not passed, the control needs to be replaced.
You already have the dial part of the temperature control disassembled, but there is also a temperature probe attached to it. Remove all fasteners holding on the existing probe and take note of the path of the probe. Install the new temperature probe along the same path as the original. Do not bend at a sharp angle and try to avoid bending more than necessary so the probe does not get damaged. Attach the refrigerator's wires to the new temperature, replacing the connectors if corroded. Replace the switch and any necessary housing screws you removed earlier. Plug in the refrigerator and set the temperature control to the midpoint setting. The refrigerator should start cooling down within one to two hours.
Note that,
The thermostat – that part of your fridge that controls the temperature – may be one of the smallest parts, but of course it is also one of the most important. The thermostat can not easily be repaired – generally speaking, if you have a faulty thermostat you will almost certainly need to have it replaced.
There are several warning signs that the temperature inside the fridge is not what it should be. An obvious sign that the temperature is too cold inside the fridge is when liquids – milk, soda or orange juice, for example – are partly frozen. Similarly, if your freezer or ice compartment is kept too cold, ice will form on the outside of packets of food that are stored in there. The bottom part of your fridge is the coldest part – you can always try putting produce and other sensitive food items on a higher shelf. Ice or frost forming on the inside walls of the fridge also indicates a problem. Food that spoils before it should is also a sign that your fridge may be too warm.
Before you spend the time and money replacing the thermostat, here are some tests you can perform to see if it is the thermostat that is faulty, or some other problem. If you feel the temperature in your fridge is not what it should be, firstly try the obvious: make sure the temperature control is set correctly. The ideal temperature for the fridge should be between 38 and 40 degrees Fahrenheit, and for the freezer temperature between 0 and 8 degrees Fahrenheit. The temperature setting may have arbitrary numbers on it, (for example 1 through 9, warmest to coldest) and simply moving this control to the next setting up or down may solve the problem. Depending on the age and make of your fridge, there may be separate temperature controls for both the fridge and freezer. Check the manufacturer’s manual that comes with your fridge to find the suggested setting for the temperature control – or call the manufacturer if you don’t have the manual. Most companies have a toll free help or troubleshooting number to call.
If you are technically minded, it is possible to easily unscrew the temperature dial, and then remove the actual temperature control box, taking care not to pull any wires away. You can then test the temperature control using a hand held device called a continuity tester probe. Set the control dial to its coldest setting, and then attach the probe. If it lights up, then this indicates a closed circuit with no obvious problem in the electrical system. Make sure your fridge is unplugged while you do this.
If your fridge temperature is too low and you cannot make it warmer by adjusting the thermostat, it may be one of several other parts that are causing the problem – there may be a leak in the refrigerant system, a defective air damper, or a situation known as cold air migration, which occurs in ‘side by side’ fridge/freezer models. Poor cooling can also be caused by frost building up on the evaporator coils – a vital part of the fridge that you cannot easily see without removing a panel on the inside of the freezer. A sure sign of this is if you see slight icing or frost build up on the inside walls, or floor of the fridge. If your fridge is self-defrosting, it may be a faulty defrosting mechanism that is causing the ice or frost build-up. One way to test this, although it is not particularly convenient, is to take everything out of the fridge, leave the door open and turn the thermostat off for at least 24 hours. Once the ice build up has disappeared, put the thermostat back on its normal setting – if the fridge then cools properly, there is probably a problem with some part of the defrosting system.
There are other ways to test that the thermostat is keeping your fridge as cool as it should. A good method of accurately checking the temp over a period of time is to leave a glass of water in the fridge for 24 hours; or a glass of cooking oil in the freezer. You can also use a thermometer – a meat thermometer is good for this. Also check the door seal and the door catch on your fridge – something as simple as the door not closing fully can cause a slight temperature increase inside the fridge. And leaving the refrigerator door open for long periods of time can also cause the inside temperature to warm up.
If you are lucky though, you may never need to repair your fridge – the average lifespan of a refrigerator is about 15 years, making them one of the most reliable and longest lasting of household appliances.
Good luck in solving the problem......
1helpful
2answers
Fridge not working
I've had this happen to my Kenmore 73503 several times. The 1st time took me a few hours to figure out what the problem was.
Basically the fridge is cooled from the freezer, so when you say your freezer is -2 degrees, it's a big tip off to the problem.
If you look very close in the freezer compartment at the back, you'll notice an opening with a little door at the top of the freezer compartment. This opening extends up the inside of the back of the fridge to the top of the fridge area via a square plastic tube.
Basically what happens in my fridge is the family loads the freezer to high especially at the top/back. This restricts or closes off the opening for the cold air to the fridge portion of the appliance ....resulting in a warm fridge, but cold freezer. Just remove the articles at the back of the freezer to correct problem. (It will take a few hours for the cold air to cool the fridge down)
Note: the temperature control unit in the fridge area controls the little door at the top of the freezer compartment, so if you haven't blocked off the opening, the next place to look would be either at the mechanical parts of the little door or the temperature control unit itself in the fridge
True TWT-72 3 Door Worktop Refrigerator Logo
Top True Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a True Refrigerator Expert? Answer questions, earn points and help others
