Meccer laptop. Why doesn't it turn on?
When I put it on charge, it only blinks a blue light. Unfortunately, the blue light does not show up again
Posted by bornwell siliya on
  • Anonymous Oct 19, 2021
    great question, no model told, is see these in Africa, are you? PC are not the same world wide and this is the WWW !
    the battery is bad, as most are now. billions of them with vast of them bad, as they all do often.
    even 1 year old, they can fail abused, as the battery make warned you.
    Another battery bites the dust, repeat 3 times for effects.
    replace ONE with BATTERY
    https://youtu.be/eqyUAtzS_6M?t=39
    here, even play this song as you replace the word ONE, with battery and feel great.
    also best song to play doing CPR (best joke?)
    now the way, tech answer, (bad battery is the physical answer, remove it) run AC power endlessly
    tech
    the old battery shorts
    the condition overloads the charger chip and the main VRM regulator, (voltage regulator modules)
    causing total power loss. even AC plugged in.
    now answered both waY.
    1: what can I do.
    2: why did it happen
    answered.
    the VRM also acts as an electronic fuse, so if there is a short it prevents FIRE AND SMOKE.
    And prevents a wrecked PC, and the loss of a $300 motherboard.
    remove the battery huge and run on AC power pack only ,even forever.
    there are 3 other cures
    1`: the 10second power button push and release. the intel harmless reset.
    2: the long hard reset (huge battery removed) starting at red words
    remove
    https://pcdied.com/PSU/hard-resets.html
    make the goal first getting BIOS to show its screens NO POST ERRORS.
ADMIN Canada
    Top Expert:
  • Computers & ... Master
  • 41,552 Answers
If you post down here Larry, you get points. Good to see you on the Leader Board, and you are catching me up!
  • great question, no model told, is see these in Africa, are you? PC are not the same world wide and this is the WWW !
  • now the way, tech answer, (bad battery is the physical answer, remove it) run AC power endlessly
    tech
    1: what can I do.
    answered.
    remove
Posted on Oct 19, 2021
Bought this blackweb charging station today and when i put my Iphone S on it it just flashes blue tried to readjust the phone and Also unplugged it and plugged it back in but still flashes blue
https://www.quora.com/Why-does-my-portable-charger-blink-and-not-charge
What does it mean when your portable charger is blinking blue? The charger senses this battery condition and as part of it's features gives the blinking indication to say cannot charge this battery. ... A steady charge light usually means that the battery is charging and a blinking light shows that it is charged.
Feb 19, 2019 • Cell Phones
Msdc blue screen on my camcorder
Try to go thru menu and do a factory reset?
Motorola hk250 bluetooth was put in the dryer now it won't work
The instruction set was discharged when the heat and static from the dryer caused the data to blank out. Motorola is the only source for repairs, and the chances are the Bluetooth is damaged beyond repair.
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Battery indicator
You can safely ignore this problem.I thought I needed a new battery but was informed that if you use on battery until it shows under 80% the light will turn blue again when charging on mains power and it will recharge to 100% despite the laptop message telling you that you should consider a new battery.That was 6 months ago and the battery is still going strong!
Hai there.... yesterday i bought new battery for my acer aspire 4520. Why the orange light keep blinking when the battery were charge???als0 there is no show the charge symbol on my screen??? I really...
when orange light is on it means it is charging and to know whether your system is charging just look at battery symbol where you will find a wire symbol on battery which show it is charging and when charge is complete orange light turns blue
2answers
No power only plug light and battery light is on
The lights are indicators of which operation does your laptop operates.
1. Power indicator is lighten to green meaning you are in the mode of charging your power.and if the power indicator turns to orange meaning you are now using battery power or the charging is finished.
2. Reading indicator is blinking meaning your laptop is currently processing but if the Reading indicator is not blinking and made a static light then your system is in hang up or not reading the processes.
3. Wireless indicator is blinking or lighten then you are in the a wireless mode connection. Also the bluetooth and Infrared connectivity.
So please check which light indicator is lighten when you on your laptop.
Thanks
1helpful
4answers
Computers & Internet Logo
Ekse
