Question about Cell Phones
How to Install Magisk & Root with TWRP?
I want to root my device. I tried but I could not do it correctly please give me some advice to do this.
Posted by Nilushi Thennakon on
Shashani
    Habit-Forming:
  • 7 Answers
Step 01:
Install TWRP
This method works by flashing the Magisk ZIP in TWRP, so you'll need to install the custom recovery before you begin. Much like Magisk itself, there are multiple ways to install TWRP.
If you're rooted, you can use this method, but note that you'll have to do a full unroot in SuperSU after you're done. If your phone has a Fastboot interface (most phones do), you can use this guide to install TWRP. Just follow steps 1-5 exactly as they're depicted, then use Method 2 in Step 7 to flash the TWRP image file for your particular model.
If your phone does not have a Fastboot interface, the instructions for installing TWRP will vary. We've covered many of these methods in separate tutorials that are linked out in the following guide, so this is a perfect place to start:
Step 02:
Install Magisk Manager
Once you've got TWRP installed successfully, boot into Android and install the Magisk Manager app. This isn't the Magisk framework, which provides root access and the ability to install Magisk modules. It's simply an app for downloading and updating the Magisk framework and managing modules.
The Magisk Manager app is no longer available on the Play Store, so you'll need to have "Unknown Sources" enabled to install it. Other than that, just head to the following link, which will show you all available versions of the Magisk Manager app. Download the newest version, then when that's finished, tap the Download complete notification to launch the APK. Finally, press "Install" when prompted.
Step 03:
Download the Magisk ZIP
Next, open the Magisk Manager app. You'll get a popup asking if you'd like to install the Magisk framework. Tap "Install" here, then hit "Download Zip Only" on the subsequent popup. Wait until you see a message at the bottom of the app's main menu stating that the file has been downloaded.
Step 04:
Flash Magisk in TWRP
Next, boot your phone into recovery mode, then tap the "Install" button in TWRP's main menu. From there, navigate to your device's Download folder, then select the Magisk ZIP. After that, just swipe the slider at the bottom of the screen to install Magisk, then tap "Reboot System."
Step 05:
Verify Root & SafetyNet Status
Next, go ahead and open the Magisk Manager app. If everything went off without a hitch, you'll see a message towards the top of the screen that says "MAGISKSU (topjohnwu)" with a green check mark next to it. This means your phone is now officially rooted, and since it was done with Magisk, it's a systemless root.
Aside from that, the main advantage of Magisk is that you can have root without tripping SafetyNet. To verify that your phone still passes Google's SafetyNet check, press the corresponding button towards the top of the screen. If you see two extra green check marks after this test is run, you're all set to go!
Posted on Oct 17, 2021
**Step 1: Install TWRP **
This method works by flashing the Magisk ZIP in TWRP, so you'll need to install the custom recovery before you begin. Much like Magisk itself, there are multiple ways to install TWRP. If you're rooted, you can use this method, but note that you'll have to do a full unroot in SuperSU after you're done.
**step 2: Install Magisk Manager**
**step 3: Download the Magisk ZIP**
**Step 4: Flash Magisk in TWRP**
**Step 5: Verify Root & SafetyNet Status**
Next, go ahead and open the Magisk Manager app. If everything went off without a hitch, you'll see a message towards the top of the screen that says "MAGISKSU (topjohnwu)" with a green check mark next to it. This means your phone is now officially rooted, and since it was done with Magisk, it's a systemless root. Aside from that, the main advantage of Magisk is that you can have root without tripping SafetyNet. To verify that your phone still passes Google's SafetyNet check, press the corresponding button towards the top of the screen. If you see two extra green check marks after this test is run, you're all set to go!
1helpful
How to Install Magisk and Safely Root Your Android
Magisk Set Up
First, you'll need to download Magisk. Connect the item by USB to your PC.
Swipe down from the top of your phone's screen and select USB charging this device > Transfer files.
If your phone does not open automatically, navigate to the spot where it is mounted. Copy the Magisk zip file to your phone's Download folder.
Remove your phone from your PC safely.
You'll need to reboot your phone into recovery now. This process varies each device, but you can usually do it by hitting the Volume Down and Power buttons at the same time.
When your smartphone restarts, you should see a screen with the Android mascot laying down and a menu with the Start option selected. Cycle through the menu with the up and down volume keys, then select Recovery mode.
The gadget will reset once more. This time, it will be TWRP. You may need to input your device password here to access the storage. Select Install when you get to the main TWRP menu.
Navigate to the Download folder in your store where you copied Magisk. Select the ZIP file.TWRP will then provide you a screen with information on the Magisk zip and the opportunity to install other ZIP files. You do not need to install anything else at this time. When you're ready, swipe the blue slider to the right at the bottom of the screen to begin installing Magisk.
TWRP will guide you through the installation of Magisk on your system. When it's finished, a notification will appear across the top of the screen stating that the installation was completed. To reboot your device, click Reboot System at the bottom of the screen.
Normal rebooting of your device will occur. After rebooting, your smartphone will be rooted and running Magisk. To check the progress of your installation, open your apps and launch the Magisk Manager.
1helpful
[Samsung Galaxy Note 8][Rooted] Can not encrypt
Rooting breaks phones about 80% of the time turning them into paperweights. Rooting changes the BIOS, the things that happen in the phone before the operating system loads. The Rooting programs are written by kids, who don't have the coding experience that the phone makers do. Your phone is broken, you just have to accept that fact and move on. There is no fix for Rooted phones, you can't put the old BIOS back..
Kingroot latest version doesn't root my Android 9. Please advise
Kingroot dont work with all models .
What you need is Reboot your phone into recovery or you can boot into it.
And flash magisk zip file and after reboot install magisk apk file you will get rooted.
For tutorial you can go to XDA.com and search for your device you will get tutorial for sure. Its very helpful community.
3answers
Need to download google play service
Hi there.
There's one way you can install Google Play Services on your device. Follow these steps:
  1. Make sure your device is 'Rooted'. According to my research, your deice is already rooted.
  2. Install 'Root Manager': Root Explorer 3 3 5 apk paid Download ApkHere com
  3. Download Google Play Services and save it to somewhere you can access: Google Play services APKs APKMirror
  4. Install the app. I'm sure you've already known by now.
  5. Just in case, install Google Play Store app as well: Google Play Store APKs APKMirror
  6. Reboot.
DISCLAIMER: If you don't know what 'Rooting' is, don't try this! I"m not responsible for your tablet blowing up or your head explodes. All the links above belong to their rightful owner, I'm not trying to claim my own rules here whatsoever.
2answers
How do I install Googleplay store app?
If you need to install Google play on your Kindle Fire HD, root your Kindle Fire device at first. However, you can't root it like other Android device with one click rooting tool - iRoot, Framaroot, Kingo Root... The rooting process may be a little complicated while it's effective and safe.
For more detailed instruction, please refer to: http://www.iroot.com/how-to-articles/how-to-root-kindle-fire.html
Afterwards, install the Google play. Open run.bat. Choose option 6 and install it.
How will i Root my FIREFLY S80 Super SU is not Working onto it.. Thanks!!
What you'll need to do is load TWRP recovery up first, then flash Super Su from recovery,that is the issue your having as to why Super Su won't install binary. There is not much to explain with this one, Android Jelly bean is hard to crack.
1helpful
How can I root Oppo Find 7a? Please help.
Yes you can easily oppo find 7a smartphone. This guide will help root your smartphone and install custom recovery like TWRP on it.
How to Root Oppo Find 7 7a and Install TWRP Recovery
1helpful
2answers
How to root my Samsung Galaxy Star Plus GT-S7262 ?
Not so hard dude
first of all download this file and put it in your internal storage (in root not in any folder)
SuperSU zip
now you have to go to recovery mode
follow :-
switch off your phone.
then Restart your phone in recovery mode by pressing Volume Up + Home Button + Power Button at the same time for some time. Phone will reboot in recovery mode.
In Recovery Mode
(navigate by using Volume Buttons and Power Button)
click Install Zip from sdcard > Choose zip from sdcard and find the SuperSU.zip file where you puted it before and tap that file.
Yes. Your phone will be rooted.
SuperSU app will be installed also check it in Menu... :-)
Cell Phones Logo
Top Cell Phones Experts
Ekse
ADMIN Canada
ADMIN Canada
Are you a Cell Phone Expert? Answer questions, earn points and help others
