Televison & Video Logo
M
Mika Morrow Posted on Oct 16, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Sanyo model number DP39D14 and I don't have the remote but whenever I plug the tv in and turn the power button on nothing happens no red light and no blue light
Larry
Level 3:
  • Sanyo Master 5,042 Answers
  • Posted on Oct 17, 2021
Larry
Sanyo Master
Level 3:
Answers
5042
Questions
Helped
1241589
Points
18413
This model set had capacitor issues in the power supply
I have a Sanyo Hdtv model # DP39D14 and plug headphones in and the tv doesn't switch to headphone mode. What am I doing wrong, if anything?
Is it supposed to work that way? Do you have to shut off the speakers first? Did you consult the manual for guidance?
2answers
Where can I buy a replacement remote control?
Check out http://EzRemoteFinder.com. This website provides a remote control search engine. Just enter in your search criteria, (mfg, model, etc.), and this search engine will search several remote control websites and return you a list of remotes to purchase sorted by the lowest price. Here is link to your search results for the Sanyo MC42NS00:
Looking for that lost remote control
Best of luck to you!
X322BV-HD*WXC100
Warranty is usually 1 year parts and labor. Contact mfc for warranty service. likely main board.
I can not get my rca remote to work on my Sanyo model DS20425
If you don't have the code, you could do a code search and when you hit the code search button on the remote, continually hit the power button until your tv turns off. Then save it, but it may take awhile. You may have to hit the power off a 100 times or more if you don't have the code.
WHAT IS CODE FOR TV SANYO?
Hello
If you wants to get into the service mode of Sanyo TV. do one moung the folloing procedure. If you are in need of universal remote code for Sanyo follow the extented solution. Your post is not clear, that is why I answers for both.
To get in to the service mode adjustments
[1]
Unplug the power cable.
* Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
* Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
* Use the {CH+} {CH-} buttons to select menus.
* Use the {VOL+} {VOL -} buttons to change settings.
* Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
* Press the {MENU} button or turn the TV off to exit.
[OR]
* Press and hold the {VOL -} button on the TV
* Keep pressing the {VOL -} button until
Universal remote codes:
Three digit universal remote code for sanyo are:
004/ 013/ 049/ 108/ 110/ 180/ 209
Four digit universal remote code for Sanyo are:
0049 0097 0110 0004 0268 0012 0108 0180
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
SANYO DP26647 blank screen, please help
U have LED front power tv light come on and bliking?Than ur power suply it dead.Power supply board must be replaced.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board.
2helpful
3answers
Universal remote px-rc1
Hi! This worked for me! I'm Leyz/leheart from the Philippines. I'm typing in CDRKing or CD-R King or CDR King Universal Remote Control PX-RC1 so that these keywords will show up if someone's looking for it too.
Mcneileric is right!
Real TV should be on! On the remote, press and hold the SET and DEVICE TYPE (in my case TV) at the same time. (Note: SET button is not any other button but the one with the word SET on it. You might have been searching on youtube and found that they are pressing other SET buttons but do press the SET button with the SET word). Then press SET again. Press the POWER button then + CHANNEL button then POWER button then +CHANNEL button then POWER button then +CHANNEL. (This process is so the remote could look for the code while you are pressing the +CHANNEL and the POWER is to see if the tv will turn off/respond to the remote). Do this repeatedly until the time that when you press the POWER button, the real TV turns off which means the real TV now responds. You will be shocked so DON'T press the +CHANNEL button anymore as this will instruct the device to look for another code. Instead, press the DEVICE TYPE button (TV for my case) to finish the set up.
NOW YOU CAN USE the REMOTE! Press the POWER button and this will turn on the TV!
Again...
TV onPress and hold SET button (yes, the button with the word SET) and DEVICE type button (TV/VCR,etc) at the same time for about 3 secondsPress SET againPress Power to check if the TV turns off^^If nothing happens, press +CHANNEL to search for codePress Power again to check if TV turns off^^If nothing happens, repeat the step between ^^ and ^^If the TV now turns off after pressing the POWER button, press the DEVICE type button to finish the setup.
Mcneileric, THANK YOU!!!!
2helpful
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
