Question about Element Televison & Video
Rc84 directtv remote program to element how to do it
Larry
  • Element Master
  • 3,548 Answers
Ask direct TV for help since it's their remote
Posted on Oct 17, 2021
1helpful
I have a Denon AVR-1600 receiver and just installed a DirectTV receiver, RC66RX remote. How do I program the DirectTV remote to run my Denon receiver?
I don't think the codes are available online?
although if you call the directTV 1 800 # they can give you the program code, really hope this helps?
tip
DirectTV RC65 Programming
TIVO DirectTV RC65 Remote Control Programming
Here are the steps to program your TIVO Direct TV RC65 Remote Control:
  1. Locate the 5-digit code for your DIRECTV® Receiver. (See Users Manual)
  2. Power on the DIRECTV Receiver.
  3. Slide the MODE switch to the DIRECTV position.
  4. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
  5. Using the number keys, enter the 5-digit code. If performed correctly, the green light under the DIRECTV position flashes twice.
  6. Aim the remote at your DIRECTV Receiver and press the PWR key once. The DIRECTV Receiver should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
Your TIVO DirectTV RC65 remote control is now setup to control your DVR. A digital copy of your remote's owners manual is available here.
Instructions for the RC65 Code Search function to find compatible remote codes are here.
I hope that helps.
tip
DirectTV RC65 Remote Manual
Tivo DirectTV RC65 Remote Control Manual
Have you lost your TIVO Direct TV RC65 Remote Control Manual?
Would you like a digital, searchable, pdf version for reference on your computer?
The TIVO Direct TV RC65 Remote Control Manual is available for download here.
In it, you will explanations of is buttons and features, and directions for setting the remote up for use as a Universal Remote, controlling all your other AV components.
Directions for entering DVR programming codes are here.
Instructions for using the RC65 Code Search function to find remote codes are here.
I hope that helps.
Do you have the code for programming the volume on a DIRECTTV remote?
go please to www.fitness.manualsonline.com or www. remotecodelist.com
God bless you
I cant get my directtv remote to work with my sylvania LC321SS9, all the codes given by the directtv console failed to program it.
Log onto www.directtv.com and click on equiptment at the top righthand side of the page,then click on remotes,mid page on the right says "program your remote" just below that click on "look up instructions" scroll down to "program your Direct TV remote control" and click on it,click on the model# of your remote control,enter your TV brand in the box and just continue to follow the instructions. Good luck !
Direct TV TC64R remote does not work in RF mode with RCA DRD486RH
The DRD486RH is both IR and RF capable but the remote that you have is obsolete.
29helpful
2answers
Can't program my DirectTV remote to control my Insignia TV (no Insignia remote code on DirectTV's remote programming menu)
I have an insignia TV 32" and I used common code 10463 to program my direct tv remote. hope it works for you.
2answers
Program remote
Hi there, I will need the Full model number of your TV, then i can see whay i can do.
I can't program my universal remote to my tv
I found these codes for this Akai (in which I'm totally dissapointed) and successfully programmed my DirectTV remote using 11675. Good Luck,
3helpful
Remote control code to program for directv receiver
i have a ton of codes i need your model# of your Directtv Receiver.
Televison & Video Logo
Top Element Televison & Video Experts
Joseph Hoffmann
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
