Do you mean the beaters? Take a look near the top of the beater shaft. Does it have a slot which holds a wire ring? If the wire ring is missing, that would explain why it won't stay in. Try shopping for a new set of beaters if that's the problem.
Does the bowl table rotate freely by hand? If not, it may need a squirt of spray lubricant. If the table rotates freely by hand but doesn't turn when mixing, look at the bottom of your beaters. The beater that is closer to the outside should have a nylon button at the bottom. This nylon button rotates the bowl as it turns. If the button is worn or missing, you will need to get new beaters.
Don't know a solution, because I am having the same damn problem.
I am very discouraged with this product.
It is a piece of ****.
I am thinking about taking it out back and shooting it with my 270 I bought.
That is the only solution I know.
the best stand mixer is a hobart n 50 its a little expensive, but if you use your mixer all the time, its worth the investment, buy 6 to 8 sunbeams, or kitchenaids, to 1HOBART N 50. metalgears in transmission, and in planetary,all the others have nylon gears
Try placing some "braces" rubber bands around the shafts of the beaters. This should tighten the hold of the shaft with the mixer and keep them more straight.
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
This may have a simple solution:
