My Windows 10 touchscreen computer is frozen
It turns on but mouse doesn't work and neither does touchscreen
Posted by Debra J Howard on
  • 5 more comments
  • Anonymous Oct 14, 2021
    hold power button for 10 seconds and release
  • Anonymous Oct 16, 2021
    what model , I presume Microsoft "SURFACE" real computer like these, and no model told
    we can not see your screen , now if mouse means mouse pad built in or external
    https://www.bestbuy.com/site/shop/window...
    no ACTUAL PC told at all, so answers will be wrong, wild useless guessing or worse yet the poor help must post for every PC made in earth using touch screeen, 12 makers?
    is the keyboard dead too?
    does and external mouse USB work,
    tell all that works not just bad, and MATTERS.
    ALEX I'd like to try topic " What's my PC "at $500 please? Jeopardy! (RIP Alex !)
    wild guess, (to show ages matter)
    Lenovo ThinkPad Helix Ultrabook
    Touchscreen Tablet PC 3698 3702, 1st 2nd Gen Generation
    2012 made ?
    tell makers name of PC first, then find model name, 2nd. (w10 tells me nothing seen vast PC with w10 installed and on old PCs does not run right ,yah even touch screens and touch pad mouse dead.
    NO PC told. we wait.
    is PC convertible??
    laptop
    notepad
    wild guess 2:
    SAMSUNG SERIES 7 SLATE XE700T1A-A06USf , mfg.2011. and w10 upgraded? gen 2 CPU,
    IF super lost post photo or PC, or its service tag and bingo fast accurate answer and tests.
    shoot photo of PC front and bottom for sure bottom tags, showing real models. BINGO,
    if you know and use the w10 hot keys on the key board the PC can be used, as can plugging in any USB mouse made. (avoid wireless with pesky batteries inside mouse)
    https://support.microsoft.com/en-us/wind...
    hit win key , then use arrow keys on keyboard to navigate, a skill worth learning IN A JAM.
    w10 has ROBUST hot key support even back to windows 3.1 days 1992 year, almost 3 decade now.
    if the keyboard side can be snapped off, say so, or tell model of PC.
    all PC's made earth fail, and do so way to fast, even 2years old on stinky laptops.
    NO PC TOLD AT ALL (models matter, 100,000's of models not one told)
    like saying my car stalls.....
    top failures.
    all batteries dead, that includes all wireless mice or keyboard or both and some convertables.
    HDD bad.
    screen bad, or just touch, or just wrong SW drivers loaded to your PC.
    of totally clueless , get it repaired in PC repair shop/
Aron
  • Computers & ... Master
  • 2,042 Answers
I would try turning it off for 5 minutes and turn it back on to see if it will work again. If it still is not working there could something wrong with your computer and your touch screen that will need to be repaired from someone that fixes computers.
Posted on Oct 16, 2021
2answers
Mouse frozen which keys to use instead my lap top works how I am able to write now. My Desk top computer mouse is frozen?
If you were using a physical mouse (instead of a track pad), then try a different mouse.If you were using the track pad, get a USB mouse and plug it in. If it works, then continue to use the USB mouse. If no type of mouse will work at all, it is a software issue. If rebooting doesn't fix the issue, you may have to reinstall windows. If you are using a mouse with a driver that was installed using a disk, try uninstalling that driver from the add/remove programs window (programs and features wind on vista and later).
2helpful
2answers
The Mouse and Keyboard are frozen and will not work. Pressed unlock mouse button but did not respond. What do I do?
Restart by pressing the Start button and keep pressing until it shuts down. Then restart.
Here is more on this subject:
http://www.computing.net/answers/windows-xp/hp-pavilion-is-frozen/162636.html
Frozen computer and mouse problems
I am assuming you use Windows XP.
Try deleting the mouse's drivers in your computer and let it re-detect them.
Right-Clickie MyComputer and drop down to the last option of Properties.
The 2nd Tab should be HardWare. On that page, click Device Manager. Scroll down the list to find the Mouse Driver, or MICE.
Expand the list. Highlight the Mouse and right-clickie it. Select UNINSTALL.
Reboot your computer.
When it all comes back up - if you mouse is still being dorky - then it is either your USB driver [same as above, only delete the USB Root Hubs (all of them) and let that re-detect upon reboot] -
OR
You mouse is dead. Try a friend's mouse.
If the friend's mouse works - Buy a new one. They are $10 at WalMart.
You can do this in any order ... Try a friend's mouse, delete USB hubs & reboot, delete mouse drivers & reboot.
One of the three is your problem. :)
(There is a very small chance that your USB hub has actually suffered a HARDWARE failure.)
2answers
Frozen mouse with a touch pad laptop computer
file:///C:/Documents%20and%20Settings/GX-620/Desktop/TouchPad_ALPS_v.7.0.1101.14_Vistax86.zip
reinstall your touchpad drivers, and make sure it is not switched off (if you were using an extra mouse)
1helpful
2answers
My laptop has the mouse pad built in and it froze up..I cant do a thing .I have tried to shut down and if you dont have a mouse working you cant even go to task manager etc..Now what? It is new I have only had it a month...
2answers
My HP touchsmart desktop  powers on but the touch screen does not work, nor does the mouse. what should I do?
my wireless mouse is frosen and i've tried new batterys and connected it to pc 10 tiimes and it still will not work
3answers
USB mouse won't work under XP in a dual boot Ubuntu GRUB 1.5
It has the latest mouse driver (logitech setpoint 4.0). Before installing Ubuntu the setup worked w/ SUSE/XP using GRUB dual boot. After installing Ubuntu XP does not see the usb mouse. Even Logitech setpoint does not have the mouse setup/configuration option. It appears that at boot it does not recognize the mouse or disables it. The BIOS has the usb keyboard and mouse enabled. Currently, I have two mices one for xp and either mouse will work under Ubuntu.
1helpful
Mouse Cursor Frozen
Try putting the computer into safe mode by shutting down the computer. Turn the computer back on. At beginning of the boot process press and hold the f8 button and select safe mode from the menu.
When the safe mode is done booting up, try moving the mouse around. If it works, restart the the computer under normal Windows startup procedures.
Computers & Internet Logo
Ekse
