Question about LG Dishwashers
LG14AW2 Dishwasher OE code after 3 minutes
After running for 3 minutes the DW gives an OE error code. I have put water in it to see if there was any obstruction. It drained perfectly. I had the drain hose disconnected and water came out and drained the washer. So, I am sure the pump is ok, the drain hose is clear but get the OE after 3 minutes. Any thoughts? Appreciate any help.
Posted by Ian Hocking on
Dan Peters
    New Friend:
  • 48 Answers
Hi Ian,
This means the water is not draining out of the dishwasher - probably the filter is clogged. Your dishwasher has a filter fitted in the drain that prevents scraps of food from entering the pipes. Please try to clean the filter, hope this is helpful.
If the problem persists please see more possible reasons here:
https://www.repairaid.co.uk/dishwasher-repairs/not-draining/
Thanks
Dan
Posted on Oct 14, 2021
  • Ian Hocking
    Ian Hocking Oct 14, 2021
    I have cleaned out all filters and arms - all run freely and the dishwasher empties but OE error after 3 minutes. I looked at the link but that unfortunately did not help.
2answers
Why does it stop running after two mins and has an error code of OE?
The OE or Overflow Error code.
The water inlet valve is an electrically-controlled valve that opens to allow water to enter the dishwasher. Depending on the model, the valve stays open either for a set length of time or until the dishwasher has enough water. However, if the water inlet valve doesn't shut off after the dishwasher has enough water, the dishwasher will overflow. If water drips into the dishwasher when the door is open, or if water collects at the bottom of the dishwasher while it is not use, you may need to replace the water inlet valve.
OE error code dish washer. hose and filter okay. runs for 2 mins and stops. water over filter area?
This is the fix for the oE error code.
https://m.youtube.com/watch?v=V04PvdyWVTM
2answers
Samsung Dishwasher (DMR57LFS): Error code oE. Fills...fills some more...then drains.
Samsung Dishwasher 0E Error - We had other appliances on that circuit. We believe when those appliances were turned on it created an undervoltage condition in the dishwasher, causing another sensor to send the high level error code 0E. We believe this is the problem because it only started after we added the new hot water dispenser on the same circuit. The problem went away when we leave it off for the whole dishwasher cycle. I'm guessing it could also be caused by brown-outs and other large electrical loads cycling in the same household. That's the theory anyway. The folks who sold us the dishwasher suggested turning off the breaker, to reset the computer. Good idea, but not for our particular case.
1helpful
Hello, LG LD 14AT1 dishwasher, starts cycle runs 3 minutes, starts stops on off no water in bottom. Then displays OE chimes! Checked tap under sink water there, checked filter inside bottom, turned off for...
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
2answers
Every other load we have OE coming up, also the drowm will not spin
LG washing machine error code - OE
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc
6helpful
Im receiving an OE error code on my LG Dishwasher Model LDF7811st. The machine runs for a little bit and then it dings a few times with the "OE" code and stops running. HELP please
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
9helpful
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
Good Luck!!!
OE Code keeps coming on screen LG Dishwasher LDS5811WW
OE error message is listed in the manual as a drainage problem so first I would check for a clogged line
4helpful
4answers
LG Dishwasher Model LD-14AW3
I have had this dishwasher about 4 years, it has work beautifully, then one day there just wasn't any power going to it. Have tried different power points and no change. Looked for a fuse, was unable to find one. The power cord coming into the machine is undamaged. Any suggestions.
Dishwashers Logo
Top LG Dishwashers Experts
Mike
Oloyede Monsuru
Steve Novak
Steve Novak
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
