Question about Sylvania Computers & Internet
Factory reset on Sylvania sltdvd1024 - Sylvania Computers & Internet
Posted by Shannon Doyle on
  • Anonymous Oct 14, 2021
    lost the manual, ? or forgot to ask maker for support?
    ask maker here.https://curtis-sylvania.com/product/sltd...
    RTM there?
    reset means reload android?? 10 GO edition
    the manual page 05 real pdf 7 tells the reset , using paper clip to push in a tiny hole, ever read the manual.?
    why not ? I found it with 15seconds work.
    then push power for 3 second to turn on, same page, read. (all this just reading the manual>
    no problem stated at all,
    is the battery now end of life and dead/?
    page 14 shows battery replacement./
    if it will not turn on, it can not be reset, if 1hour battery charge fails the battery is no good now
    as see on most tablets, dead.
    hold power button for 10 or 30 seconds, yet? and release.
ADMIN Canada
    Top Expert:
  • Sylvania Master
  • 40,545 Answers
I need to do a factory reset to my Sylvania sltdvd1024 Tablet.
STEP 1 - Hold the device with a finger on the screen and fingers on the back "MENU" and "On/Off" keys. "Press the required keys if you want to apply a factory reset. The device will then display the following screens in sequence without the need for any further key pressing. "Recovery OK!Jan. 4, 2021
MY Grandson bought the tablet sylvania sltdvd1024 with dvd ...
SYLVANIA SLTDVD1024 touchscreen not working
The screen would have to be replaced and the parts that allow the screen to work would also need to be replaced as well.
Sylvania sltdvd1024 DVD tablet. How can I reset it?
The following manual's troubleshooting section refers to a recovery from safe mode on page 16 by repeatedly pressing a button. Sadyly, if this does not work, you might want to consider your warranty.
http://legacy.curtisint.com/html/CustService/Manuals/INSTRUCTION%20MANUAL%20FOR%20SLTDVD1024.pdf
Alternatively:
If you can navigate the screens you can, tap settings,default set, yes.
How can I factory reset my SYLVANIA SMARTBOOK WHEN I CANNOT remember password
You can't reset the password unless you know the current password. All you can do is a factory reset. There's a small hole on the back marked "reset" about 1in. diagonally from the right lower corner of the data plate. Leave the tablet switched on and push a straightened paper-clip into that hole for 10 seconds. This should reset it to the factory specs.
How do I factory reset my Sylvania TV SST4324 to TV mode?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option.
2answers
Sylvania SmartBook
Try to reset to factory settings & update to current drivers.
I want to do a full reset; can you tell me how to do that please? it is a sylvania netbook synet7wid. thank you
A full system factory reset is done by turning on the computer and as soon as the screen lights up hit your F11 key. It will then take you to the factory reset screen. Just note, you will loose everything when you perform this step, so it's your choice and at your own risk. The computer will reset back to factory default settings.
3helpful
2answers
Can the sylvania video/mp3 player-smpk8854b be reset?
if you can navigate the screens you can, tap settings,default set, yes.
try reset on top of player if its acting up.
firmware is not available for these players.
Computers & Internet Logo
Top Sylvania Computers & Internet Experts
Mike
WTF Chuck.....
WTF Chuck.....
Paul Bade
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
