My Atomic Clock runs one minute slow. Can I change that with the "Factory setting" button? Or, is there another way? I've tried unsuccessfully to manually move the minute hand.
The clock was accurate when new but changed at some point. It runs just fine otherwise.
Sadly, there are many clocks designated as atomic clocks. No search yields Atomic Clock as a brand itself. Clocks and watches usually have procedures so complicated by the time you finish reading them, you can't see straight enough to tell the time. I think you need to do a google search for atomic clock but attach the brand to that plus user manual. If it is a famous brand, there might even be a YouTube video regarding adjusting it. If you don't have the instructions, it will be perplexing. Even the brand site may not offer sufficient help. https://www.amazon.com/atomic-clocks/s?k=atomic+clock&dc&ref=a9_sc_1
To correct the time on your Sharp Atomic clock, you will need to reset the time zone. To do this, press and hold the "Time Zone" button for 3 seconds until the time zone flashes. Then, press the "Hour" and "Minute" buttons to adjust the time zone to the correct time zone. Once the time zone is set, press the "Time Zone" button again to save the settings. The clock should now be displaying the correct time.
Set Time Hours and Minutes:
Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press the Adjust/Channel button to change the hour.
Press the Time/12/24 to go to minute
Press the Adjust/Channel button to change the minute.
Press the Time/12/24 to set.
Set Alarm1 and Alarm2:
Press the Alarm1/Alarm2 button to toggle either Alarm1 or Alarm2 to set.
Pres the Alarm1/Alarm2 and Alarm2/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press the Alarm1/Alarm2 to go to minute
Press the Alarm1/Alarm2 to set.
Set Calendar Year:
Press Calendar/C/F and Max/Min buttons at the same time for two seconds and it will start to blink the calendar year.
Press the Adjust/Channel button to change the year.
Press the Calendar/C/F to go to Month.
Press the Adjust/Channel button to change the Month.
Press the Calendar/C/F to go to Day.
Press the Adjust/Channel button to change the Day.
If you have a Howard-Miller 625-236 atomic clock, do you need to change the time zone only or manually set the time?
To set the time zone, press Mode (furthest left on the back of the clock) to get to the Alarm Time Mode. Then press Set (2nd from the left) to change the time zone. Then press Adjust (the middle button) to select the correct time zone. Press Mode again to exit the settings mode. To manually set the time, you need to remove the battery from the clock. Then reinsert the battery after 30+ seconds. Press and hold Set until the hour begins to flash, then press Adjust to change the time. Press and hold to quickly change the hour. Then press Set to change to the minutes and use Adjust to set the current minutes. Repeat this routine to set the seconds, month, date and year. Press Mode to exit to the Time mode.
I see you need help with your radio controlled clock.
Place your Seth Thomas atomic clock face-down on a table or desk and
locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the
back of the clock. Press the appropriate button to set the time zone.
Turn your attention to the small lithium battery-powered digital clock
display on the back of your clock. With the correct time zone set, the
digital display should accurately reflect the current local time.
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
Hello Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner
If it is a radio controlled clock and it is consistently out, then the hands need re-setting. I have hand a similar experience with my watch, so I fully understand the problem.
You can adjust the hand settings by pressing the right buttons!
If you have the instructions, then refer to the to adjust the hands. If you do not have the instruction, then go to the makers web site and look for manuals download.
How
to Change the Time Zone Press and hold the “-“ button for 3 seconds the letter P
will appear where the seconds are than press and release the “-“ button until
the correct letter for your time zone appears.The four time zones are P is Pacific, M is Mountain, C is Central and E
is Eastern Time zone.Press the SET
button to confirm or leave the setting to confirm and exit automatically.
This is more of a Clarification than a solution. I've determined that the SS-5000 is not recognizing the changes to DST that happened in 2007.
From 1986 to 2006 this was the first Sunday in April to the last Sunday
in October, but starting in 2007, it is observed from the second Sunday
in March to the first Sunday in November, adding about a month to
daylight saving time.
So in March the clock is still trying to keep the "earler" time and in November it's trying to keep the 'later' time.
I'm contacting HomeMedics Support to see if there's a resolution.
press set button repeatedly -you get timezone mode and change your wished time zone
and select your zone then press set button.
to normal mode and adjust the current time.
