Question about Frigidaire Refrigerators
Frigidaire model FFHS2322MBKA
The Ice Maker was overflowing with water. Kept filling with water even after raising arm to turn it off. Then turned water off, and it still tries to fill the tray.
Posted by Charlie Lafland on
Frigidaire side by side FFHS2322MBKA ice maker stopped working, but still dispenses water
Change the Water Solenoid Valve. This is a dual solenoid valve, one side is for water thru the door ... the other side supplies water to the ice maker and probably is bad. good Luck! Handy Henry
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
How do I turn off ice maker
Good Afternoon Rsimmon5,
I see that you are trying to turn off the ice maker to your Frigidaire refrigerator, model# FRS6R5EMB. You will be moving the signal arm to turn your refrigerator off.
To begin ice production, lower the wire signal arm to the DOWN or ON position. The ice maker turns off automatically when the ice container becomes full. To stop the ice maker, raise the wire signal arm until it clicks and locks in the UP or OFF position.
If you have any trouble with your ice maker continuing to make ice after this, I recommend contacting either the manufacturer or an authorized technician in your area. Hope this helps.
-Best Regards-
WP
1helpful
Frigidaire ice maker model jbnd-28 stopped working
Hello - If your ice maker has stopped producing ice completely, please check these, in this order:
It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. A clogged water filter or a blocked supply water valve may also lead to low ice production.
The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Should these suggestions prove to be ineffective, contact a professional to diagnose the unit.
Frigidaire plhs3teesbe model won't make ice
Hello - If your ice maker has stopped producing ice completely, you can try to check the following:
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Can you turn the ice maker off like other refrigerator ice makers? I didn't see anyway to turn my ice maker off or do I empty the ice out everytime?
Most ice makers have a control arm that raises and lowers to check for a full condition. It usually raises during the dump cycle and lowers during the fill cyle. If it is unable to lower (because the bin in full) it should shut off the fill cycle. If that function is not working, then if you move that control arm to the fully raised position, it should shut of the fill cycle, until you manually lower it again.
I turned off my ice maker with the switch on the ice maker now it wont turn back on. Is there a reset or a way to reset the ice maker
How did you know it is not on? A single cycle for an ice maker takes some time to complete. They don't have reset buttons. You just lower the arm to turn it on and raise the arm to turn it off. The cycle goes like this. The tray is filled with water then as the water freeze it reaches a temperature that which triggers a sensor. Then a heating element melts the bottom of the ice then the mechanism rotates and dump the ice. Cycle starts again. This single cycle can take a few hours to complete. If the cycle is interrupted by turning off the water, it could take a while because the ice maker will go through the cycle regardless.
Kenmore Coldspot Model 57577791 S/S Ice Maker Problem
Probably the solenoid (electric valve that opens when the ice maker calls for water ) is leaking and has to be replaced (it's a very common problem ) . To be sure the solenoid is the problem , turn off the ice maker by raising the arm up , and check after a few hours if is any water in the ice tray , if yes the solenoid is leaking , if not , the ice maker control board has a problem , and to replaced it will cost you almost as a new ice maker.
Oct 19, 2009 • Freezers
1helpful
Our model 532 keeps over filling the ice maker causing a build up on the back and down all of the drawer. We can turn it off and thaw the entire box and the water keeps filling the tray even though the ice...
The fill valve for the ice maker could be stuck partially open and dripping into the ice maker. If this is the case shut off the water line to the ice maker and if the water stops you will need to replace the ice maker fill vavle
4helpful
2answers
Ice Maker Not Making Ice
Ice maker was installed properly, when you put the arm down it doesn't call for water to fill unit. It doesn't make any kind of noises at all. The water is turned on and all plugs are in there are no kinks in the line but when the arm is truned down for it to call for water nothing happens
The is for a frigidaire refrigerator.Ice maker is all new..
31helpful
2answers
Ice maker won't stop making ice
OK, there's two possible issues but you have to figure out what is happening. Does the ice maker continue to make ice forever and would fill up the whole freezer section in time OR does the ice maker just "over make" ice that overfills the bin which then falls out? If the ice maker just keeps making ice you need the motor module replaced but if it can be turned off by moving the lever up then you need the "modified lever assy." that is on our service bulletins.
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
