Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
My Rowe 100B Jukebox was working great now it's showing Checksum 6A00?
As soon as this pops up the CD start to fade in and out?? How do I fix this??
Posted by Cindy on
  • Larry Ng
    Larry Ng Oct 07, 2021
    not a computer posted to computers. help.
    so bought dead or ran for 30 years and died just how? no history told. SORRY OUT OF THE BLUE SURE.
    or you or others did wild EPROM updates and failed.
    btw those EPROMs can self erase if window on top of it is exposed to sun light (super bad) or room light for years. (as in a PCB board sitting on a sHelf in a room top of shelf and not black label sticker covering the WINDOW of the EPROM (a round small quartz window) UV erased is fastest.
    Rowe CD-100B Jukebox 1991 (30 years old now) one can expect thing that old to fail easy.
    so all CDs tried fail" my guess this RIG is 100% dead.
    that check Sum is not off the CD, those are CDDA music disks
    my guess (wild) is the firmware is failing on the processor board. (most boards made with eprom did a checksum first to make sure the firmware was not corrupt and if is errors out and halts (uCODE)
    see thishttp://www.biltronix.com/Rowe_CD100B_01....
    ask for help there?
How do you clear the map in a rowe ami laserstar nostaglia cd jukebox
hi
What model is your Rowe Ami jukebox, there will be an information label on the back or inside the jukebox with the serial number and the model type. We can suggest a solution once we know your model type.
Testimonial: "Hi Alan Do you have a website etc as I have two jukeboxes both AMI Rowe, one is a Ti2 this has a speed and selector,problem, the newer one I just need guidance on it plays ok this is an R-91 Many thanks Lisa"
1helpful
Rowe CD100A Jukebox CD carousel keeps turning.
if you got the service manual with it, it will tell you how to pull up the error codes and what to check.....I got lucky cause I just bought one and it had the manuals in it...mines is a rowe ami cd-100c. ....I just googled ur model and a pdf manual pop up for downloading. ...hope that helps!!!!
3helpful
4answers
I have an ami Rowe Model Laserstar CD100-F Jukebox that I purchased at a fundraiser. It works great but it has somehow switched from the mode where it plays without inserting $ to only playing when you put...
most all "early models: Rowe CD 100 Laserstar's
Put the slide switch in service position. Go past the errors (if any) by pressing Popular and Reset simultaneously then enter "55" the display should say "free play off" then hold down the reset key and push 9. This will toggle between "off" and "on" Toggle until the display indicates free play "on", then release the reset key and press the popular button. Put the service switch back in to the play position, The display should say "FP" however not all models display it exactly the same. If your computer's battery is good this setting will be retained. If you have to load the factory defaults for any reason OR another problem (dead battery) is causing the factory defaults to be loaded when you power on, this free play setting will be reset to "off" after power is interrupted.
1helpful
I've owned an Antique Apparatus CD-91 counter model CD jukebox for more than 15 years, and it's only been used in homes. Around 8 years ago, I started to have a problem where the CD, once place on the...
Hi Nick,
If you still have this problem I would contact Bruce Wentworth in the USA, listed below are his details.
Regards
Alan Hood
ami-man
UK
Bruce Wentworth A&B Jukebox Repair 56 Old County Rd. Plaistow NH 03865. A&B Jukebox Repair specializes in the repair of Rowe circuit boards in Rowe ...
www.abjukeboxrepair.com/
1helpful
3answers
Rowe Jukebox CD-100E. When I turn it on the
AT THIS TIME YOU ARE NOT SURE IF THE PROBLEM IS IN THE LASER ASSEMBLY, OR THE AMPLIFIER?
BORROW OR RENT, AN AMPLIFIER HOOK IT UP TO THE OUT PUT ON THE LASER OUT PUT ON THE LASER CD OUT PUT. LOOK AT LASER UNIT IT HAS A MARKING ON IT THAT SAYS AUDIO OUT PUT. PUT CABLE TO A SECOND AMPLIFIER.
THAT WAY IF IT STILL FADES. THEN THE CD LASER IS THE PROBLEM . IF THE SOUND IS GOOD THEN THE AMPLIFIER IS AT FAULT
DOCTOR FIX IT
3answers
I have rowe ami jukebox Eagle Laser Star and its amp seems to be dead sin have no sound justa a buzz. Need to find one or how to repair it.
CALL AB JUKEBOX SERVICE--ASK FOR BRUCE--TELL HIM LES FROM RMC VENDING SUGGESTED YOU CALL HIM.-
603-382-6272
1helpful
2answers
My cd rowe ami jukebox is stuck in scan/transfer mode
You say you do not have the digital display lite up, have you checked all of the breakers on the power supply?
If not do so. Rowe Ami jukeboxes are very prone to dry joints (cold joints in the USA) this is cracking around the soldered pin on the connections to the boards.
If you can solder correctly then check out the printed circuit board on the power supply. I would retest and see if the display now lights after correcting a fault on the power supply.
If that has not made any difference then proceed to the Mechanism Control Board and the Central Control Computer (CCC) and check again for dry joints.
If you can not solder with any confidence then send in your boards to a Rowe Ami specialist for testing/repair.
Regards
Alan Hood
ami-man
UK
1helpful
Rowe CD 100 that will not play all Tracks
Are you initalizing the CD's in your jukebox after you install them?
If so it should play all of the tracks.
Regards
Alan Hood
ami-man
UK
2helpful
2answers
Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Regards
Alan Hood
ami-man
2answers
Rowe cd jukebox
There is something called a "play stimulator".
It's actually a program setting. When the jukebox is in a pub it is set to play a random record now and then to remind people there is a jukebox. It's programmed that way and can be turned on or off.
What you have is a setting for flipping the pages for the same reason.
It's not a fault it is actually doing what it has been told. You can time your watch to it.
I have no idea how to change it but rest assured it isn't a fault as such. It's been set up that way. You need a Rowe expert.
Dave F.
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
Top Wurlitzer Audio Players & Recorders Experts
 Francisco Mauricio...
mike simpson
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
