Question about Samsung Computers & Internet
How to extract PIT Files from Samsung Devices by using ADB Commands on the computer?
PIT file extraction
Posted by Nilushi Thennakon on
Shashani
    Habit-Forming:
  • 7 Answers
Install Android SDK on your computer and go to Settings> Developer options and enable USB Debugging on your device. Only like that the procedure will work!
  1. Launch a command prompt on your computer by placing the mouse pointer at an empty space on the desktop and then pressing Shift key. Choose the Open command window here option;
    Connect your Samsung handset to the computer;
  2. In the command window, enter the following command:’adb devices adb shell su’;
  3. Then, grant root permission on your device;
  4. Type the following command: ‘dd if=/dev/block/mmcblk0 of=/sdcard/out.pit bs=8 count=580 skip=2176’;
Your handset’s PIT is finally backed up to the internal storage of the device. Save it on your PC.
Posted on Oct 07, 2021
No space for new apps
· 1.Check if you really have sufficient storage free.
Ifstorage is free enough
then
· 2.Clear the app chache data with the clean master app or the included cleaning app forjunk data cleaning.
Can also bedone by using adb bridge (Search on the net you will surely get something onstackoverflow.com).
If thisdoes not solve your problem.
Then try this:
· 3. (This solved my problem)
Usuallythe default install location in android is set to automatic. If for any reasonif it is change to something else it can be problematic like you experienced.
Setting up ADB (required)
->get you phone connected to a pc over the USBcable provided (Make sure you have your proper driver installed [usually it'sinstalled])).
->Turn the "debugging mode on"through the settings (You can search over the internet it's easy)
->download the adb_inteface.rar tool andextract it somewhere.
->open command prompt. Change the currentdirectory to where you extracted the adb.exe and all files from the attachment.
->type
adb devices
if it returns with last line like this
List of devices attached
cfcd5eec device
This means you have successfully set up theinterface.
Running Commands
->check the default storage location bytyping on the command prompt:
adbshell pm get-install-location
If it results something like:
open: Permission denied
2[external]
Or
1[internal]
This means it may be a problem which forces the Android OS to save on specified location 1 for internalstorageand 2 forexternal storage.
You may fix this by running the following command:
adb shell pm set-install-location 0
here 0 means automatic storage depending on the storage space availability.
Meanwhile you may get messages like:
open:Permission denied
open: Permission deniedYou can ignore this.
this is probably because your phone is notrooted.
Hope this is useful.
How do I unlock my straight talk phone if I dont know the password?
Today, I had the same if not similar problem, so I contacted the carrier. They directed me to a blog geekbuying.com/index.php/2013/12/03/how-to-erase-your-lock-screen-password-or pattern.on your android-device/#.Up20100bju4. Although there are several methods to unlocking a lock phone, as I was trying method 2, where ADB command to help you erase the password, if you still don't know what is ADB, and how to use it, here is the instructions: http//www.howtogeek.com/125769/
If you understand the ADB very well, then, the command is here: adb shell rm /data/system/gesture.key
this is for erasing the password;
adb shell rm /data/system/password.key
this is for erasing the pattern.
both methods are all based you have open the USB Debug. How about you forget to open that? If you don't open the USB debug and there is only two ways to erase the password:
1- flash the firmware again for you device; (because different phone has different firmware update instructions just google the information you need)
2- wipe the data and cache. (instruction is here http://smallbusiness.chron.com/wipe-data-cache-android-316
As I began downloaded some of the requested files I stumbled across unlock your android device without USB Debug on, or a google account and still retain your files, using emergency calls or sim swap. I decided to utilized this one as I was not sure if my DeBug was on or off and to my surprise it worked.
Method 1 - The Screen lock bypass
Will work on all android devices running android 2.3 x or below no matter whether rooted or not.
How to use: Extract the gingerbread lock bypass file anywhere on your PC, install drivers for your phone using pdanet. Connect your device to the pc using USB cable, go to the extracted folder, run the Double_Click_Me.bat file and enter 1 to continue in the command window. Try unlocking your device now. The screen lock will be bypassed.
Method 2 - This will work on all android devices 4.0
How to use - Install drivers for your phone, you can search online using your phone model, connect your device to the pc using USB cable, go to the extracted folder. Run the Double_Click_Me.bat file and enter 1 to continue in the command window. Try unlocking your device now. Any password/pin/gestures that had been currently stopping you from having access to you device have been cleared.
I most definitely cannot take the credit as I don't know all of the websites I was on, but I made copies to follow the instructions and on the last two that seem to have worked for me and I hope it works for you their is a man name Andrew Miracle, android download and on top it had Tecmie Info Center. I am giving you word for word as I use their quotes because it differently worked for me.
My passion is to help people and as I stumbled across this website fixya and I hope I have been successful with the help of others to help others.
Forgot attern on screen lock on lg 76
Solution 1: use your gooogle account
Solution 2: do a resset (all contacts and messeges will be lost)
Solution 3:
Connect your device via USB cable and enter those commands through ADB:
adb shell
Reboot your android device and now supply following commands
adb shell
cd /data/data/com.android.providers.setting-s/databases
sqlite3 settings.db
update system set value=0 where name='lock_pattern_autolock';
update system set value=0 where name='lockscreen.lockedoutpermanently';
.quit
Restart your device and it It will accept any pattern lock.
My galaxy y when trying to install custom rom get bricked.now only when i connect phone to pc galaxy y logo popps but automatically shutdown when plugged out.it wont go to download mode help !!!!
ODIN- Galaxy Y
Latest Firmware-Link1 . Link2
Samsung Kies USB Driver- Link1 .Link2
Extract These Compressed Files Using Winrar.
Let's Begin:
  • Open Odin Folder and run ODIN. ( For Win 7 and 8 users should " Run as Administrator " Option)
  • Put your phone into download mode. ( Press VOL Down+- Home Button+Power Button). Now it will ask you to press VOL UP button. Press VOL UP
  • When your phone has entered into download mode, connect it to your PC using USB cable.
  • Now your device will be detected,( On task manager stop all processes related to kies)
  • Next we have to select each files from the extracted folder for ODIN.
1. PIT File: Click on the pit file option on ODIN, and now select the PIT file from extracted firmware folder.
2. Bootloader: Select Boot file from extracted folder
3. PDA: select the PDA file from folder
4. PHONE: Be careful in this step, you have to select the MODEM file instead of PHONE file from folder.
5. CSC: Select the GTS5360 named file.
  • After selecting all files, Press START button on ODIN. The Flashing process will start now. You can see a blue progress bar moving slowly. This shows that the flashing process is being done.
  • Wait for the process to finish.Make sure the USB cable is plugged in and never disconnect the device while process is going on.
  • After everything is finished, you can see a green colored bar appearing with PASS printed on it. Now the phone will restart automatically. Allow it to restart.
  • Once restarted the phone will be brought back to factory settings and will be unrooted also.
There you have it, Your Galaxy Y has been restored to factory settings !
How to get the wallpapers from the downloaded files with rar format?
Use your computer if you have WINRAR installed in your computer it wil help you extract all files in RAR format or you can download Blue FT its extract files eg rar, zip, jar, thn etc..you can download it here :www.mobango.com or www.wapday.com! Please don't forget to rate if it was helpful !
1helpful
I downloaded jzip but need instructions on how to use it
after downloading and installing jzip,
right-click the file you wish to decompress find the jzip option in the right click menu. click extract to folder or extract all or extract to /[file name].
alternatively you can right click compressed .zip or .rar files and choose open with... browse to jzip and the compressed file will open with a jzip window. you can then choose extract all or extract to folder to move the files out of the compressed file into an accessible place on your computer.
6helpful
2answers
Open rzr files
There is no any software which can extract rzr files..
Just change your file extension to .rar and use winrar to extract it...
regards,
4answers
Churches are not loaded as POI's. on my ONE XL-S It usuall will not recognize any church a.k.a. place of worship, even if I enter the name. Please help!!
The Points of Interest (POI) database consists of two files:
An OV2 file, which contains the POI's information ov2.jpg A BMP logo of the POI (optional) bmp.jpg
Step 1: Download and unzip the POI file.
1. Download the POI zip file. Save the file on your computer by selecting “save” when prompted. Save the file in a place where you can easily find it again for step 3 of the installation (e.g. on your Desktop or in My Documents)
2. Unzip the POI file by right-clicking the file and selecting Extract All..
  • This will run the Extraction Wizard. Choose Next.
  • Click on Browse... and choose a location on your computer where you want to extract the files. Click Next.
  • Once the files have been extracted, choose Finish to view the files.
Step 2. Connect your TomTom to your PC
Connect your TomTom to your PC using the USB data cable or dock. When prompted if you want to connect to the computer, tap on YES.
Step 3. Copy the POI files from your PC
1. Go to the directory on the local hard drive of your PC where you extracted the files in Step 1.
2. Highlight these files then right-click them and choose Copy.
Step 4. Copy the POI files to your TomTom
1. Go to mycomputer.jpg.
2. Double-click your TomTom under Devices with Removable Storage tomtom.jpg.
3. Then go to the map directory, for example the folder na.jpg.
4. Righ-click and Paste the POI files into this folder.
5. Right-click your TomTom device and choose Eject before removing it from the USB cable or dock.
You can now use the new POI on your TomTom device via Navigate to... > Point of Interest.
Apr 07, 2008 • GPS
Computers & Internet Logo
Top Samsung Computers & Internet Experts
Ekse
Oloyede Monsuru
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
