Question about HP Office Equipment & Supplies
How to Fix HP Scanner Not Working Error? - HP Office Equipment & Supplies
Posted by Walter Little on
Jessica Davies
    Novelist:
    Scholar:
  • HP Expert
  • 80 Answers
When you replace your latest Windows OS or any other version of the software, Your system may not recognize the scanner at times, or confusing messages may occur while scanning anything. At HP Chat Support, our skilled tech-specialists are available to help you resolve your issue quickly and easily. It becomes difficult for the user to determine the root cause of the scanner not working problem.
How to Fix HP Scanner Not Working Error? - hp scanner not working problem-zak4cq3qcmezhidavlxcz1vh-6-0.png
How to Fix an HP Scanner That Isn't Working
Here are a few methods that may assist you in resolving your HP scanner not working issue. You don't have to test them all if one of them solves the problem; simply work your way down the list one by one.
How To Fix HP Scanner Not Working Issues?
While scanning with the HP scanner, users may face issues. HP scanners, like any other machine, might develop technical problems. These issues can cause your HP scanner to stop working properly. Most of the time, you can easily fix HP scanner not working issues on your own.
For more information, Contact HP Customer Care Support.
If this guide does not resolve your scanner's issue, you may also contact the HP Scanner Support Center via their official website.
Posted on Oct 14, 2021
3answers
How to fix scanner error 6?
herewith 3 suggestions (try searching the HP forum or search engine 'scanner error 6'). Read all of them before you decide to do anything and only then decide which order if any to do them depending on ease vs likely effectiveness.
HP LaserJet 3055 Scanner Error 6
HP Laserjet 3055 Scanner Error 6
6.July.2015
1helpful
2answers
What is scanner error 2 on hp laserjet 3055
Flatbed scanner is bad replace whole top half p/n q6502-60116 approx. $150 - $200
2answers
How to fix Aj5030 error clean up scanner
Clean scanner lamp and optical lance .if not the problem fix need to change scanner unit
2helpful
4answers
2answers
My Printer is showing scanner error 6 on the
you may have a problem in your cartridge, replace it first and then replace the scanner unit
81helpful
5answers
SCANNER ERROR 20 of HP LASERJET M1120 MFP
PRINTER: HP DESKJET M1120 MFP DISPLAY SCREEN SAYS; "SCANNER ERROR 20"...
ANY IDEAS HOW TO FIX?
MANY THX!
2helpful
2answers
HP Laser Jet 3030 not work
remove scanner glass and use compressed air to blow out the scanner
4helpful
5answers
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Hp scanjet 5590 error in comunication when trying to use the scan to buttons on the scanner
I downloaded the following files from HP's website
setup_full_5590
setup_emc_5590
col10862
cit207355-hpcom-patch-v8
hpinstantshare
and followed the procedure that i found on the web at hppt://hpanswers.blogspot.com/2008/03/unexpected-internal-error-has-occurred.html
wich give full instructions on how to cleanly remove the hp software and what files you need to run to help fix the problem.
this is a fix but it is has not got my scanner working the way that it used to but it is working a lot better that it was.
Thanks
Sproket
Open Questions:
Vinaya Kumar...
Vinaya Kumar...
Ekse
