Question about Panasonic KXT7730 Telephone
My Panasonic KXT7730 was working fine for many years. Suddenly it is dead. I checked and replaced all cords nor dial tone or lights.
Does it have a battery . Or is it a fault that needs to take to a service center
ray gallant
    Top Expert:
  • Panasonic Master
  • 73,774 Answers
Buy a new phone
Posted on Oct 24, 2021
Why did my fax machine suddenly stop working?
Check that the memory is not full. Also, make sure a setting like (auto-dial 9 for outside line) is set incorrectly.
I need panasonic telphone model no KXT7730
A 7731 and 7730 are interchangeable, as well as the 7735 and 7736. All 4 models are display phones and only differ in the display size and how the buttons light up under the dial keypad.
Carl
There is no response from the phone when plugged in to the telephone jack. No lights, no dial tone, nothing. As if its dead. The jack is ok since other phones work when connected to it. Its a hand me down...
What other phones work? Check the base cord and make sure it has 4 pins. If the jack works for other phones, then take that same cord and plug it into the base of the 7730. Worst case is that you take it directly to the phone system and plug it in there to see if it works.
Carl
Hello, please i want to know how to set up speed dial on the KXT7730 that is not the main line ie not on 0, or 101 on the switch board
Guessing that you already know about SYSTEM speed dials, then the 12 buttons on the right side of your phone are the PERSONAL speed dials. When you get dial tone on the intercom, you can dial "9" and the system will either give you a dial tone, or the highest line in the system. If that is not a working line, you need to fix that first (system program 400 assigns lines in service).
Once you have that, a PF button is programmed by pressing PROGRAM, the button, and dial 9 + your number dialed the same way as if you had pressed a CO button then STORE. You can keep pressing PF buttons and programming numbers. Then press PROGRAM or pick up the handset and drop it back down to end programming.
Carl
How to program store number in the KXT7730
Under any system, you can always press PROGRAM + a button, dial a sequence and press STORE. What number are you dialing?
If it's an outside number, then the sequence is generally 29 on the left side or 9 on the right side buttons. If inside, then 1+ext on left and ext on right. The left side buttons have lights and will monitor extensions.
Carl
13helpful
4answers
Panasonic phone KX-TG4500 base not turning on, I have had it for 3 years and all of a sudden it died, like a battery goes off.
I could tell the base unit was about to go a few days ago. Have had the phone for years with intermittent problems but it has been for quite awhile now. However, the screen on the unit started to blink a bit a few days ago. Had a feeling it was about to go but the phone kept working until this morning when it suddenly dies. After reading that changeing the cord might work, I replace the unit power cord with one from my handset and the phone is working again! Thanks for the suggestion!
1helpful
2helpful
No dial tone in home. I have checked the cords
unplug all phones and cords check each phoneindividually until u find the phone causing the problem, i had this problem a couple years ago and came to be one of the cord plugs..good luck..floyd
I have a Brother MFC 7220 - it won't print but says manual feed. Also the telephone is not working. All this was fine yesterday. The machine is about 1 year old.
Hi zoltansz
Have you tried the following
Use the telephone cord going in to machine on a regular telephone. If this works cord is fine. Plug cord back in to machine. Press the dial button on machine if you hear a dial tone check the settings for Pulse / Tone dialing (refer to manaul). If you don't here any dial tone the fax modem on the machine is faulty (posible lightning strike on telephone line. You will then have to take the machine in to a service centre.
Please feel free to uase the Repair Service Directory on this site to locate a service centre close to you.
Regards
Go-Tech
Panasonic KX-FM220 fax machine does have a dial tone
I would double check your phone cord. There is usually 2 jacks in the back of the fax machine. 1 is for Line, and 1 is for phone.
Your phone cord should be hooked up in the LINE jack that goes to the wall.
I would also double check your phone cord on another phone to make sure the cord is good.
If you look at the clear connector that you plug into your wall and fax machine, does it have 4 copper/gold color wires contacts imbedded in the clear plastic connector?
Another thing to try, if you fax machine has a Line and a Phone connector, try plugging in a phone in the PHONE connector. Then hook up another phone cord going from the LINE to the WALL jack.
If you get a dial tone on your Phone, then you know you have it connected correctly. If no dial tone, then I would go back to the phone cord.
check those things and get back to me and I will see if I can help you with more suggestions.
Good luck.
Mac =)
Panasonic KXT7730 Telephone Logo
Top Panasonic Lands Phones Experts
Ekse
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
