How to get GOOD Answers
Please, please please, when you ask a question, give as much detail as you can.
To get good answers, you HAVE to ask GOOD questions!
I know you are sitting in front of your exercise bike, and you want a manual for it, but it is no good putting a question in the category of exercise bikes and just write
'I need a manual'
This happens time and time again. It doesn't even matter if the partial image in the category is JUST LIKE YOURS! We need, make and model to help you.
If you are asking questions about vehicles, or anything that may change on a yearly basis, please also include the year.
Today, a young fella posted 'I need an assembly diagram'. I posted an assembly diagram for an exercise bike. He responded "you gave me details on an exercise bike, I want a diagram for a Co2 BB Air-rifle ". You see the problem :>)
If you do post something really vague, don't be surprised if I have some fun with you as our Computer Guru Larry has done!
Posted by ADMIN... on Oct 29, 2015
a printer, it is. by sharp i bet if this post matches last , why post 2 time one topic,?
OK so you posted 2 times on 1 problem is that it, here is your other post
Where I can locate the queue (corrected) in copier AR6020V - The Office Equipment & Supplies
is this a printer copier question?
no PC told are you printing from a PC or doing copier direct copy? we can not see you push buttons,no
the printer is called SHARP printer, copier AR6020V
the print queue, in Windows PC is task bar right an icon of printer shape clicked shows queue, status for 30+ years.
does print , copy and scan. w10. so says your manual, is the w10 software from them loaded , must be.
this is a very large and very complex business printer, etc.
my wild guess is you do not know how to check the printer for errors?
step on on any printer made is do the printer self test page or calibration.
do that first just to see if the thing works.
free service manual on line
and users
https://www.sharp.com.hk/en/download/630...
Does the printer fail self tests
or only fails from unstated PC to Printer. only.
or both. not told. yet.
page 101 says e machine does not print. (Data notification indicator was blinking.) ...
go to page 105
in brief, no paper loaded or jammed
PC sent ******* sized paper not matching paper try type.
paper size led blinks is that clue.
this printer is LAN connected, on same sub lan as PC or fails
the printer USB option kit can be USB connected , IS IT?
this printer has LCD front display
and its own web page that can control all t his too. learn to use that?
step one is do a test page, the manual covers this.
page 33. covers that. please read it.
is the ONLINE lamp glowing top row right.? if not press it or it will never print remotely ever.
is LED 27 error glowing?
page 38 clearly
Before using other than SHARP recommended paper, make a test copy to see if the paper is suitable.
you do know ,right if the PRINTER is in stand by mode it must warm up first to print right? in the manual.
lamp top right moon , blinks when the machine is in an auto power shut-off mode
blinking data can mean and be slow if processing data. (graphics or?) page 36
test ,,mode in the manual asked 4 or more time but never told and is secret code 64 command.
not told if you were doing PC print or self copy print, we can not guess what you do so tell it?
if copy self mode fails, scan to print, right triangle button above, read the error codes next
then do a self test print. if printer fails in ANY way. BUT IS TRICKY.
https://www.youtube.com/watch?v=e7b2eW5-...
#, > interrupt key
interrupt key ,led out.
see blank job LCD left
keypad 64
copy key triangle hit
keypad 1
copy key hit
one hard set of steps for such a simple act,.
THE 2ND WAY IS TO MAKE THE WEB PAGE WORK PER THE MANUAL
AND DO TEST PRINT FROM THERE.
OR IF USB CONNECTED, USE THE APP FOR THE PRINTER AND PRINT A TEST PAGE.
