When you say "ear speaker" fdo you mean an eabud headphone?
Just check plug size; there are 3 1/2" and 2 1*2" plaug. Do a google search and buy a good quality.
Actually, Motorola headphones are quite good, so might be some particular issue with yours.
I've used Sony headphones too, but be careful with FAKE Sony products.
try not using headphones or listening to loud music for a few days if the sound goes away then you have been damaging your ears with too loud sound. If the problem persists see a doctor as you may have Tinnitus or other hearing/medical disorder that a doctor should have a look at.
I use a multimeter to check the connections to the ear pieces. I set it to the diode function. The meter's test probes also have a very low dc voltage and this causes a 'click' sound in the working earpiece. Some earphones have 3 wires, others have 4 wires. In the 3-wire setup, one wire is the common wire. It goes to the ground connection of the mini plug. The 'click' sound on the left ear piece should go to the tip of the connector. The 'click' sound that you get on the right ear piece should be soldered to the 'ring' of the mini plug. The 4-wire type of earphone/ headphones cable usually have two wires that are the same colour. These are the ground or common connections for both right and left. I hope that this helps. A multimeter or vom is a necessity. Len.
The sound on all the stock kits I found to be too low. What I did was create a custom kit and altered the dynamics of all the pads and cymbals - once you're in the dynamics settings, just hit the pads/cymbals the hardest you normally would and save that setting!
Hi, repairing headphones is easy and interesting one, you want to check the speaker busted out steps: deassemble your device so that speaker leads are visible, connect a power supply of 5v or less to speaker leads(busted one) scratch wire with leads if speaker murmurs its working go further steps if not throw it and buy a new one
if it works
buy a cable similar to your headphone cable(cable with stereo pin )
i
you know how to solder it ,do it your own or watch this video for guidance
and assemble it check you headphone regard, cseian
could be caused by the way you wrap them up the cords should never be wound tightly it causes a short and it just so happens that earphones are made of light weight wiring to make them seem to disapear when wearing them so what to do is instead of winding them when your done simply fold them loosely so to speak
I don't have one, but are you sure the ear piece itself is bad? Usually, the problem is in the plug, cord, or termination at the ear piece. Troubleshoot with an ohmmeter (pocket DMM has one) and repair with a soldering iron.
Check for a loose connection in the wire. Wiggle (carefully) the wire around both the headset where it sits on your heat. Also, check the other end (plug) to see if there are any shorts. If this simple "wiggle" test shows nothing, there may be a problem with the driver (speaker) in the right channel in your headphone.
Another thing to check and this should be obvious: make sure your balance on your stereo/receiver is set to be in the middle and not to the left.
