Question about RCA Audio Players & Recorders
RCA model rs 2620 only have sound out of one channel on the CD source but both channels works on the rest of the sources
Posted by Darrell William... on
  • RCA Master
  • 19,166 Answers
Barring a bad connection or a switch, there are integrated circuits called OP AMPS that can fail. There is no outward sign of failure, you need a signal tracer etc to find it.
Posted on Oct 01, 2021
Mixer XLR main output to AVR Receiver as RCA not sound on main speakers
It sounds like the issue might be with the routing of the signal from the wireless microphone to the main output on the mixer. Make sure the wireless microphone is plugged into the correct input channel on the mixer and that the channel is properly selected and turned up on the mixer.
Also, make sure that the main output on the mixer is selected as the output source and that the level is turned up to an appropriate level. It's possible that the level might be too low or the wrong output might be selected.
If you're still not getting any sound, try plugging in a different audio source (such as a phone or MP3 player) into the mixer's input and see if you can hear any sound through the main output. If you can hear sound from another source, then the issue might be with the wireless microphone or its connection to the mixer.
No right channel on AV2
First, does TV sound without external sources work on both channels?
With the one RCA connected and getting sound, unplug it and plug into other channel. Any sound? If not, remove it and plug the other RCA by itself into the left channel. Sound? If yes, plug it into the right channel. No sound? If not, bad TV input.
If you do get sound on that other channel with a single RCA, then you have either a bad cable or bad source. Reverse RCA's on source and try same test, plugging each RCA into each input on TV one at a time.
If the TV is bad, you will get sound on just the left channel regardless of which RCA you use.
Need Source Dode for an RCA TV model DETK185R.
The RCA DETK185R TV can be controlled with Universal Remote Controls. I tested several.
The best match was a 4 digit universal remote from GE. Model Number 10841. Code 1961 worked almost everything.
With a 5 digit remote from RCA, model number RCRN04GR, Code 12372 worked Power, Channel, Volume and Input.
A 3 digit remote from GE, model RC24912-B. Code 166 was able to control Power, Channel, Volume and Input.
An old 3 digit remote from RCA, model RCU-403A. Code 062 was able to control Power, Channel and Volume.
Most remotes from GE and RCA will use the same code numbers. So even if you have a different model remote from GE or RCA, these codes may work.
These codes should work with other TV models in this series from RCA, including Detk215r, Detk186r and Detk156r.
I have the rca L46WD22YX5 and I change the main board and the audio board because the tv loose the analog channels and no audio in any source also I cant change the source (av1av2hdmietc)What can I do?
Ouch my RCA does the same thing. Perfect picture but no sound and no analog channels. The only inputs the work are HDMI 1,2, and 3 so I have been using it as a computer monitor and running my sound the my surround sound.
RCA TV E09397AB How to set to channel 3 or 4
I would suggest to unplug the TV from the power source for a while. Before plugging the TV to the power source, connect the VCR and play a movie or have some signal for the TV to store channel 3 into the memory. You might have to do the autoprogramming if the above did not work.
Let me know if you need further assistance.
1helpful
I have a new rca receiver and have it hooked up to my dvd player which works fine. I have it hooked into my tv and Im not getting sesurround through my tv how can I connect to the tv to make it work my tv...
Take a clue from the 10-year old vintage of the TV and the two analog audio cables. It's Dolby Pro Logic Surround at best, not Dolby Surround in the modern, digital, multi-channel sense.
TV's are not the source nor the end of a multi-channel audio chain. Feed this thing a 2-channel source from a Cable Box (into the "TV" jacks), DVD, Video Tape or CD with proper Dolby Surround encoding and will seem to open up the sound field a bit and kick in a little surround effect. It can also simulate a Hall effect and Dolby 3 stereo.
http://en.wikipedia.org/wiki/Dolby_Pro_Logic
TV channel sound from a different channel
I just unplugged the tv from the power source and disconnected the cable connection and then reconnected them back after sometime. The TV started auto programming after turning on and that resolved the problem.
Yamaha RX-V757 No Left Channel Output - Video Sources Only
First - make sure it is not a defective cable by reversing the leads/colors on the inputs if problem then goes to the right channel then you know it is a bad cable/RCA, etc., connector. I would try that first.
Thanks,
dthomas
Rca rs 2620 power but no audio
I need to see if the manual has any method of button pushing to get the sound back on. Otherwise, I am not an electronic type of guy that has soldering tools, can tell a resistor from a plug, etc. if that is what is needed to get the thing going with sound.
Only the right channel working on the amplifier
first check on all your cabling, speakers and input sources for loose/defective cables. can you tell me what brand is your amp and model? does it employs digital source switch or mecahnical switches only.
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
