Question about Kenwood Car Audio & Video
I have a kenwood cd reciver and I can't turnoff standby mode
Posted by Rafael Alcala on
  • Kenwood Master
  • 18,856 Answers
This is usually an indication that the power board has a bad component and the signal wont switch on. The problem is usually related to capacitors and unless you want to replace the whole power supply (if you can find it,) the repair is down to the individual components and it technical in nature requiring troubleshooting gear and soldering skill
Posted on Sep 30, 2021
Cant get it off of stanby
Did you try pressing the source (src) button?
9helpful
3answers
How to set time
1. enter stanby
press the [src} button
select the "stby" display
2. Select the clock display
press the [clk] button
3. Enter clock adjustment mode
press the [CLK] button for at least 2 seconds
the clock display blinks
4 Adjust the hours
push the control know towards [fm] or [am]
Adjust the minutes - push the control knob towards ['>'] 5. exit the clock adjustment mode
press the [clk] button.
if this helped you please feel free to rate the solution. If you need further assistance please feel free to follow up with a comment. Thanks, Midwest-tek
17helpful
Cant turnoff the demo mode in my Kenwood KDC-MP142 stereo
get in to "menu" (hold magnifying glass), scroll to "demo mode" (am or fm button), push volume knob in and hold for about three seconds. Should work, that's how I did it.
My dodge wire diagram for an 04 dodge ram does not match the wires in the dash color wise. i have power to the kenwood reciver but no speaker output in the truck only subs and amp have sound
wire diagrams for both your truck and any kenwood deck they will all be the same
or you can find the speakrs unmask them turn them over and look at the wires conneted to them then match them up with the wires you need to connect the cd player harness
2helpful
My kenwood ktv 717 dvd is stuck on stanby mode
good day, you might want to try removing your battery terminal to reset the program of the radio. hope this helps, have a nice day
Cliks off when you turn up volume
This is an indication of protect mode. One thing to test here:
Does the unit shutdown only when you change volume? If you try turning up the volume really slowly, will the unit remain on?
Thanks,
Dan
9helpful
How to use mp3 with kenwood kdc mp235
turn radio to stanby. hold function key until a menu appears. then switch on aux in. this should alow you to plug ipod in throough aux in on source menu.
My stereo kicks off as soon asyou turn it on tuner,CD,or AUX.if you reset it it comes right on.it also stays on if you leave it on stanby.
Sounds like you have your constant power, and remote power wires mixed up. While your at it check all the connections and splices. Something is loose, maybe a ground as well.
Car Audio & Video Logo
Top Kenwood Car Audio & Video Experts
 Francisco Mauricio...
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
