Question about Candy Refrigerators
Candy CPCA240FFK top fridge door seal required?
Hi all, Does anyone know where I can buy a new fridge door seal for my Candy CPCA 240 FFK. Measurements of existing seal are approx. 524mm x 603mm All the ones I can see online for this model number seem to be for the larger bottom freezer door; 526 x 747mm. I need the slightly smaller fridge door one. If anyone can recommend someone/somewhere I'd be very grateful. TIA
Posted by Robert Faulkner on
ADMIN Canada
    Top Expert:
  • Candy Master
  • 42,943 Answers
They need to be for the model itself as opposed to by size
Candy CPCA240FFK Seals - Fridges & Freezers - eSpareshttps://www.espares.co.uk > ... > Candy > Seals
Fridge/Freezer Door Seal. 3.6. Genuine spare part for select models of Candy, Hoover and Kelvinator fridge and freezers More information. In Stock.
Candy Door Seal for CPCA240FFK - ES929589 - eSpareshttps://www.espares.co.uk > product > door-seal
Will this part fit my Appliance? Yes. This part is compatible with Candy CPCA240FFK Fridges & Freezers. Not what you're looking for?
Candy CPCA240FFK Fridge & Freezer Door Seals - Ransom Spareshttps://www.ransomspares.co.uk > ... > CPCA240FFK
Buy Candy CPCA240FFK Fridge & Freezer Door Seals from the authorised stockist. Low prices with our Price Match Promise & next day delivery - Ransom Spares.
Candy CPCA240FFK Fridge & Freezer Spares & Partshttps://www.ransomspares.co.uk > ... > Candy
Buy genuine replacement Candy Fridge & Freezer CPCA240FFK spares from an authorised supplier. Price match promise and next day delivery.
Posted on Sep 29, 2021
  • Robert Faulkner
    Robert Faulkner Sep 29, 2021
    Hi Candy Master, thats a great name btw lol...
    Thanks for your reply and those links, but I have visited each one and all are the wrong size for what I need. Hence me including some measurements.
    I have an old CPCA240FFK as the sticker inside suggests, as well as in the manual. These door seals will fit the bottom freezer door as that is bigger than the top fridge door.
    I have measured, measured, and measured again to make sure I am not mistaken, but these seals are bigger than my fridge door, that not even 700mm, so definitely not 747mm.
    The width of the door, 524, or actual 526 is neither here nor there, that will fit fine. But 603 compared to 747mm is way too big.
    I dont understand how one model no. can have different sized doors... unless mine is so old... or has had the wrong label stuck in it. I need a door seal closer to my specific measurements.
    Any ideas?
    TIA
  • ADMIN Canada
    ADMIN Canada Sep 29, 2021
    Hi again Robert. 'Candy Master' is added by the site as well as 'GE Master', LG Master', or Hotpoint Master' depending which question I am answering. 'Admin Canada' was the name I gave myself, 'Andrew' is my given name.
    What I would so is phone a local company to your country like eSpares and talk to them. If a door gasket (the proper name) is dependent on the Model Number AND Serial Number, they will tell you.
    Here is one on eBay, you can see it says both doors are the same gasket, which is unlikely even though they do has some stretch. This advert shows yours in the drop down list.
    This seal measures 747 x 526mm and can be used on either the fridge or freezer door, depending on your model. White Fridge / Freezer Door Seal - 747 X 526mm
    Fits the following Candy Fridge & Freezer Models: Click on down arrow below.
    I checked for door gaskets in your size and they don't exist. Copy and paste this. Don't remove the "quotes".
    https://www.google.com/search?q=Candy++f...
I need a manual for candy fridge freezer
Hello there,
Please enter the model number of you refrigerator in the space below, it will give you the user manual of your refrigerator.
http://www.espares.co.uk/usermanuals.aspx?ma=775&nl=CPCA240FFK
or in
http://www.candy.it/libretti/libretto.cfm?id_line=15&ricerca=1
Hope this helped. All the best Elect_Comp
My candy fridge freezer fridge part is freezing! the light keeps clicking on and off. The food is either frozen or warm. never cold as usual. I would like to know if i need to buy a new one. It is 7 years...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Candy fridge light not working changed bulb but still out fridge is working ok
check your door switch is not stuck in the closed position
then use a volt meter to ensure that your getting the proper voltage to the light socket
Candy Frostfree Fridge freezer, model CPCA240FFK
1st of all conferm that the compressor is automatically (through Thermostate) going to ON/OFF or not, if it automatically goes OFF, i sugges its OK. and if not its no problum. (Minimum 4 hours rest is Must of a compressor, u can maunally OFF it for daily 4 hours Sleep)
Take Care
Shafky
Freezing food in my refrigerator
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Fridge running light(green)flickering
hi,thanks for your e-mail i couldn't find a solution and the fridge was fairly old we bought a new one,cheers,vic.
Fridge freezes contents
Check the door seal is not split,it may be letting air into the compartment
Candy cpca240ffk compressor running.
i don't have a diagram but im familiar with that problem its either a bad relay on the compressor a bad thermal over load in the relay box mounted on the compressor terminals or a bad compressor don't know where you live im in usa here you can get an after market relay with a start capacitor and if its not the compressor will fix the problem
1helpful
FREEZER DOOR WONT STAY CLOSED ON "CANDY" FRIDGE FREEZER
Check to see that the front of the fridge is raised at least 1/4 of an inch higher than the back.
Refrigerators Logo
Top Candy Refrigerators Experts
Muzahura Frank
ADMIN Canada
ADMIN Canada
ray gallant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
