Question about Kenmore Microwave Ovens
I have a built-in Kenmore Elite Microwave open Model # 363-63694302 that has an exterior broken handle. Where can I buy one and how do I remove the broken one and put a new one in?
Posted by Gerald De Beck on
ray gallant
    Top Expert:
  • Kenmore Master
  • 73,786 Answers
WWW.SEARSPARTSDIRECT.COM
Posted on Oct 19, 2021
How to replace light bulb on kenmore elite microwave 63673
I Agee with Ray - You can gain access to the lamp holder by removing the outter wrapper - unplug the power before you start
What is the cause of the smell of burnt plastic coming from my kenmore elite microwave?
Frequently this is caused by a loose connector to a thermal protection device (a TCO) or some other connector that has a plastic sleeve over it. The connector is loose, which is causing heat, which is melting the plastic. You would have to remove the cover to find the bad device and connector. This is a job for a professional microwave repairman.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Why is bulb so hot on cooktop light on Kenmore Elite Microwave Hood combination
depending on the type of bulb ( sounds like a halogen? ) turn it off for cleaning
1helpful
Kenmore Elite Microwave oven 63792 doesn't heat - all lights, turntable, fan, etc. work just fine.
Most likely it would be a bad magnetron since the light, turntable, and vent fan are running.
Handle on Frigidaire Microwave broken, probably because of heat from gas burner below - this is a defect becaquse the microwave oven was manufactured to be built-in above range. Frigidaire has finally...
im kinda confussed as to why Frig would do that,,,
but if you send the model number im sure we can help
most times repacing the door is really just a matter of lifting it off the pin hinges after you have removed the vent
but i can be more clear with the exact model
2answers
Kenmore mirowave # 72162643200 handle is broken
I have the exact same problem and the cost for a tech to replace the door is $80 less than buying a new one. They have to remove the unit from the cabinets and pull off the exterior box to unscrew the door hinge. Mine is only 3 years old. I also bought a new oven range. Never really use it. Decided it was time to use the self cleaning. It did not work. $280 to put a new board in. 4 months later I went to clean it and again it did not work. The f*^ing thing only cost $500. Decided Easy off will have to do. Kenmore s*&ks
As for the door... I very CAREFULLY used super glue/ gel and it did the job!
Microwave Ovens Logo
Top Kenmore Microwave Ovens Experts
Gerry Harvey
Gerry Harvey
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
