Televison & Video Logo
Question about Hisense Televison & Video
I have a Hisense TV Model 58RGE no sound no picture. When plugged in power light flashes three times in series. Does have 12volts on power board. Do I have a power board or main board problem?
Posted by Willie Bandy on
Larry
  • Hisense Master
  • 4,679 Answers
Most likely neither, on the majority of Hisense sets it has been bad LED backlights
Posted on Sep 27, 2021
1helpful
2answers
Hisense TV Red Flashing Power Light Has Sound But No Picture
1. Why hisense TV red flashing power light has sound but no picture
There could be a few reasons why your Hisense TV has a red flashing power light but no picture. It could be an issue with the TV itself, the power supply, or the input signal. Let's take a look at each of these possibilities in turn.
2. How to fix hisense TV red flashing power light has sound but no picture
If your Hisense TV has a red flashing power light but no picture, there are a few things you can try to fix the problem. First, check to make sure that the power supply is plugged in and that the TV is receiving power.
Next, check the input signal to make sure that it is compatible with the TV. Finally, if the TV itself appears to be the problem, you can try resetting it.
3. What to do if hisense TV red flashing power light has sound but no picture
1helpful
2answers
My Hisense tv model75h6570g has sound and a black screen there is no trace of a picture with a flashlight and the standby light flashes around 20 times before shutting off
Hisense only has 10 blink codes, on most brands they're helpful but not as much on Hisense, in 9 out of 10 sets it turns out being backlights, we've had sets before in our shop where an image wasn't visible, but it still turned out being bad lamp strips. Power boards are a bit different on Hisense sets as loss of backlights can put the set in sleep mode leaving only the standby voltage. Best way to troubleshoot the set would be with a backlight tester
1helpful
My Hisense 55" Class - R6 Series, Model is 55r6e, HV550QUBH10, the problem I'm having is that the red light is blinking, and it's like the screen is dim and it's boot looping, and so I looked...
No it will not be the tcon board clicking and if you see the logo that board is working. Your going to need to get some voltage readings from the power board and see if it's working ok for starters. Next would be unplug the backlight connector and see if the sound goes away, if it does you have bad backlights and I think this will be the issue
Hisense 58R6E no sound no picture?
This model had a lot of backlight issues with the lamp strips being bad, order a new set and install them and it will work again, but be careful handling the panel, it's VERY fragile
2answers
Where would the fuse be located on my 55 inch hisense tv
Unplug the TV's power cord and hold the power button directly on the tv ,keep holding it for 20 secs or so then let the tv sit unplugged for a couple of minutes before you try it again.
I have a Hisense led tv model F39V77C.
Yeah, replace the set since it appears to be trashed. But if you have a few bucks lying around you might want to try replacing the unit's power supply to see if that resolves the many issues you have.
2answers
On my Hisense 50K23DG LED TV, I have sound but no picture.
LCD & LED TV Repair - No Image & Blank Black ... - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen CLICK HERE to BUY ... I have an LG ...
Hisense 50K360G has audio no video will not turn on logo ...
? 1:48
https://www.youtube.com/watch?v=xI3MpZukKm0
Nov 20, 2013 - Uploaded by After Hours Tv & Pc repair
Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http://bit.ly/ShopJimmy6 Want to ...
All comments on LCD & LED TV Repair - No Image & Blank ...
https://www.youtube.com/all_comments?v=xUzCLgoSPGM
I have sound and picture but no backlight. .... how do you replace the back lighting on a led lg tv? ... I have a 42 inch LED LCD combo DVD TV made by RCA.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - Hi, I have an RCA 32" LED 1080p TV that is less than 2 years old, and it has already lost the video. I can hear sound, and I can see lights in the ...
53 HISENSE complaints and reviews @ Pixxed Consumer
hisense.pissedconsumer.com/
Hisense led lcd tv m no. 32k20DW s. n.32J135216H06497 power on light blinks then stays red i have sound, no picture.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Top Hisense Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
