Tcl 55r617 how to remove bezel
Back cover bottom part of bezel removed and screws on side of bezel removed
Posted by gaits Rodrigue on
  • Anonymous Sep 25, 2021
    TCL 55" Class 6-Series 4K UHD Dolby Vision HDR Roku Smart TV - 55R617
    https://www.fixya.com/troubleshoot/tcl/t...
2answers
How to remove the instrument cluster cover 98 chevy cavalier
The cover-is that like a bezel? Older cars always used screws to hold the bezel in place. On lots of newer, the bezel or cover just has plastic clips that snap into holes or slots. If you see no visible screws, try pulling the cover off, starting at one end. Once the cover is off, you can see the screws that hold the cluster to the instrument panel.
2helpful
2answers
How to replace the headlight switch assembly on a 1997 dodge grand caravan
The best I can offer is for a 1996 caravan:
REMOVAL
  1. Remove steering column cover.
  2. Remove over steering column bezel.
  3. Remove left end cover.
  4. Remove screw at left end of cluster bezel and headlamp switch.
  5. Remove screws holding cluster bezel to instrument panel from each side of steering column.
  6. Disconnect clip holding cluster bezel to instrument panel from above right vent louver.
  7. Separate cluster bezel from instrument panel.
Disconnect wire connectors from back of the bezel.
INSTALLATION
  1. Connect wire connectors into back of the bezel.
  2. Place cluster bezel in position on instrument panel. Use care not to place hands on louvers.
  3. Connect clips to hold cluster bezel to instrument panel. Use care not to add pressure on the A/C louvers to seat the cluster bezel clips.
  4. Install screws to hold cluster bezel to instrument panel on each side of steering column.
  5. Install screw at left end of cluster bezel and headlamp switch.
  6. Install left end cover.
  7. Install over steering column bezel.
  8. Install lower steering column cover.
Replace lcd on gateway NV57h77u
I disagree. The procedure is so easy no Service Manual is needed
1) Remove ALL power. Remove the AC adapter, and Battery.
2) Open the laptop.
The plastic frame in front of the LCD screen is the Display Bezel.
(Gateway? Believe they call it the LCD Panel Bezel)
Down in the BOTTOM corners, next to the Hinges, are screws to be removed. One in each bottom corner.
There are Screw Covers over these screws. The Screw Covers need to be removed.
Little round covers I believe to be made of plastic.
(Some models they are made of synthetic rubber)
I use a computer pick to Gently remove them.
Some use the tip of an X-Acto knife. I do not recommend this as there is a possibility of injury.
Perhaps a large darning needle. (Needle you sew with, but is Large in size)
Pick up at one edge of Screw Cover. Screw Covers are held on by a type of rubber cement.
I LIGHTLY stick them to the Display Bezel for safekeeping.
(Yes. They like to stick to the tool, your fingers, and it seems passing jets in the sky.
If you are careful with them, you should be able to reuse them.
If they do not stick anymore, use a toothpick, and apply a TINY dab of rubber cement to them/it )
Once the Screw Covers are removed use a No.1 Philips screwdriver, or equivalent Jewelers screwdriver; to remove the 2 screws.
The Display Bezel has TABS going around the exterior perimeter, of it's inside edges.
These Tabs snap into matching LATCHES on the Display Cover.
You can come from the Outside edge, where the Display Bezel meets the Display Cover, and use a thick guitar pick.
The guitar pick is wedged into the parting line, of where the Display Bezel meets the Display Cover.
Once a 'crack' is formed in-between the two, then the fingertips are used to gently start popping the bezel from the cover.
You slowly go along with your fingertips, and work along the top, then sides. By the time you have both sides almost loose, the Display Bezel usually pops off.
I like the flex method.
Come to the inside edge of the Display Bezel.
Where it meets the LCD screen. I suggest start on the Right side/Middle.
Use a fingertip, and lift up the inside edge of the Display Bezel up a little. Can't lift up at that spot? Move over. You are at a Tab/Latch.
With this spot lifted up a little, use the fingertip of the other hand, and slide under next to it.
Now use your fingertips as wedges, and pop the Display Bezel loose a little at a time.
I start at the Right side/Middle as stated. Left hand fingertips go DOWN the right side, Right hand fingertips go UP the right side.
Then I go across the Top, and down the Left side.
MOST of the time, as stated; the Display Bezel usually pops off when right side, and left side are most of the way popped loose.
NOT always though!
Sometimes you have to pop EACH and EVERY Tab/Latch loose.
Also; watch around the Hinge area/s.
Display Bezel can get hung up around them.
Go slow, and gently work the Display Bezel off, around the Hinge areas.
Display Bezel popped off, sit back; relax. You just did the hard part.
Wasn't so tough, huh?
This is what the Display Bezel looks like removed,
http://www.ebay.com/itm/Gateway-NV57H15U-LCD-Front-Bezel-15-6-AP0HJ00021-/171020787909?pt=LH_DefaultDomain_0&hash=item27d1a220c5
The MAIN view shown is a BACK view.
In the smaller views underneath, the 4th view from the Left, shows the FRONT view.
If you SET your mouse cursor in the middle of the Main view photo, the Zoom In feature is enabled.
You can CLICK on any of the smaller views, to make them appear as a Main view.
You can also see that the Hinge Covers, are an integral part of the Display Bezel. Shows you that when removing the Display Bezel, these Hinge Covers may need to be worked off of the Hinges.
Of course, may not; as I have previously stated.
The LCD screen is an Assembly. It is composed of layers.
These layers are kept in the factory set alignment, by a metal Screen Frame.
The Screen Frame resembles a picture frame.
There are THREE screws on each side of the Screen Frame.
These screws (Philips) go through metal Brackets, and hold the LCD screen/Screen Frame; to the Display Cover.
The Brackets are an integral part of the Hinges,
http://www.ebay.com/itm/Gateway-NV55-NV57-LCD-Left-Hinge-Rail-Bracket-AM0HJ000100-/400334888754?pt=LH_DefaultDomain_0&hash=item5d35d19f32
On EACH side, there is 1 screw towards the Top, 1 screw towards the Bottom/Middle, and 1 screw towards the Bottom.
Remove all 6 screws.
At the Top is the Webcam Cable. Unplug it from the Webcam Module.
(Cable pulls to LEFT side, facing laptop)
The TOP of the LCD screen is now tilted forward.
The Video Cable plugs into the Bottom side.
There should be a piece of clear Mylar tape, holding the Video Cable connector in place. Carefully peel it back, unplug the Video Cable from the LCD screen.
Remove the LCD screen.
Reverse steps to install new LCD screen.
For additional questions please post in a Comment.
Regards,
joecoolvette
A) http://www.insidemylaptop.com/replacing-lcd-screen-on-gateway-nv57h13u-laptop/
B) http://www.youtube.com/watch?v=ENmPg46IB9Q
1helpful
3answers
Need to know how to replace a cracked screen on dell adamo 13
Hi
Click here to know how to replace and also to know more about the replacement instructions.
Regards,
Saleem
1helpful
How do you remove bezel from compac presario cq62
1) ALL power removed from the laptop. Remove the AC adapter (Charger) and Battery.
2) Open the laptop, lay the Display Assembly back as far as you can.
At the bottom on the outside corners, there are two rubber like screw covers. One in each corner.
Carefully remove these (2) with a computer pick, or similar device.
The screw covers are held on by a type of rubber cement. If you carefully start one edge up, and lift it off, you can reuse the screw cover again. Lay it down on flat surface, glue side up.
(Yes, they like to stick to the pick, and to your fingers)
Underneath the screw covers are Philips head screws. ( X )
Remove them.
3) To remove the Display Bezel go to the middle of the bezel at the top and bottom, and flex it up a little.
Do the same with the right and left side.
The bezel will pop up, and out.
{The Display Bezel has protrusions that are tabs, going along the inside edge. These tabs snap into the Display Enclosure. The top cover of the laptop.
When you carefully flex far enough, some of the tabs will pop out.
For your first time it may give you a sinking feeling in your stomach, because for the first two, or so, you'll think you're breaking something.
When enough tabs are released the Display Bezel will come off.
The plastic used for a laptop is space-age plastic, and pretty tough stuff, but do not get too rough with it }
http://h10032.www1.hp.com/ctg/Manual/c02623133.pdf
Regards,
joecoolvette
1helpful
2answers
How do I remove the invertor from a Qosmio F20?
The inverter is located behind the bezel at the bottom of the screen/lid and in between the hinges.
The bezel has screws that fixes it to the lid and these can be hidden by stick-on plastic covers. Use a thin sharp point to lift these plastic covers off to reveal the screws. Remove these screws.
The bezel has small plastic catches that clips it to the lid and may also be fixed to the LCD screen with double sided tape. Use a thin blade and insert it between the LCD screen and the bezel and gently ease the bezel off. Start at the bottom of the screen and gradually work along the edge and continue around each side to free the bezel.
Be CAREFUL not to scratch the LCD screen and DO NOT apply too much pressure to the face of the LCD screen because you can crack the glass surface and ruin the LCD screen.
Once the bezel is removed then you can get access to the inverter to remove it.
13helpful
How do I remove the radio from a 1998 Honda CR-V?
UNSNAP PUSH-PIN FASTENERS FROM BOTTOM OF CENTER CONSOLE
AND REMOVE BOTTOM PANEL.
2. EXTRACT 4 SCREWS FROM BOTTOM EDGE OF BEZEL. EXTRACT 4
SCREWS FORM INSIDE DASH BELOW POCKET. PULL CUP HOLDER/
POCKET ASSEMBLY OUT OF DASH AND REMOVE.
3. OPEN GLOVE BOX AND REMOVE STOPPERS. EXTRACT 2 SCREWS
FROM RIGHT SIDE OF CENTER DASH BEZEL..
4. FROM BELOW STEERING WHEEL EXTRACT 2 SCREWS FROM BOTTOM
EDGE OR PANEL, UNSNAP UPPER EDGE OF PANEL, UNPLUG, AND
REMOVE.
5. UNSNAP TOP EDGE OR CENTER LOWER BEZEL, UNPLUG, AND REMOVE.
6. EXTRACT 2 SCREWS FROM SIDES OF POCKET.
7. UNSNAP RADIO/AC CONTROL DASH BEZEL, UNPLUG, AND REMOVE.
8. EXTRACT 2 SCREWS FROM EACH SIDE OF THE RADIO BRACKET
ASSEMBLY TO REMOVE RADIO FROM DASH/AC BEZEL.
2helpful
Driver side mirror installation (and removal of old)
Inside the pull cavity on the window switch bezel there is a cap in the bottom of the cavity.Remove this cap and there are 2 screws there you need to remove,then remove the window switch bezel.
There will be a screw there in the door panel where the bezel was covering up,remove this.
Under the door handle you will see a small square cover,remove this and you will see another screw you need to remove.
You will see 2 more screws at the bottom of the panel you need to remove.
Then lift up on panel and remove.
You will then see 3 nuts holding mirror on,remove these and remove mirror.
Dashboard Gauge
  1. Disconnect and isolate the battery negative cable.
  2. Remove Over Steering Column Bezel Replacement.
  3. Remove over steering column bezel.
  4. Remove left end cover.
  5. Remove screw at left end of cluster bezel and headlamp switch.
  6. Remove screws holding cluster bezel to instrument panel from each side of steering column.
  7. Disconnect clip holding cluster bezel to instrument panel from above right vent louver.
    1. Separate cluster bezel from instrument panel.
    2. Disconnect wire connectors from back of the bezel.
    INSTALLATION
    I wouldnt Recomend This Procedure To Anyone juse for Cleaning Purposes Unless Your VIEW OF IT IS "SERIOUSYL IMPARED IF it Moisture Has Accumilated Behind Face of it Then Find Out WHY and Resolve THAT PROBLEM FIRST Onherwise Here you Are. Have A Great DAY !! And Please Dont forget to RATE Me Thank You !
2answers
Manual showing how to remove DVD-ROM Drive from case for Presario 5000?
REMOVE CASE SCREWS FROM REAR CASE COVER.CASE COVER SLIDES OFF FROM FRONT TO BACK.DVD IS HELD BY 4 SCREWS TWO PER SIDE DISCONECT POWER LEAD AND RIBBON CABLE YOU GOT IT,RICHARDM69
Open Questions:
Televison & Video Logo
Top Televison & Video Experts
Ekse
