Question about Sony Computers & Internet
Sony 65 tv shows pink purple image
Suddenly I have sound and screen is pink and garbage everywhere
Posted by Constantinos... on
  • Anonymous Sep 23, 2021
    CLICK BROWSE ABOVE AND CLICK CARS
    DO NOT POST TV TO COMPUTERS. POST TO TELEVSION FORM
    just clicks and OMB TELEVISION FORUM and SOY too.
    https://www.fixya.com/troubleshoot/sony/...
    see?
Larry
  • Sony Master
  • 3,325 Answers
Is this a LED LED or plasma TV?
Posted on Sep 23, 2021
My HP 5880n TV has started showing purple lines everywhere. Particularly in images that should be shiny. Images of water are the worse and look almost all purple as each shiny part is surrounded by a thin...
I got some water between the 2 screens at the bottom of my HP 5880n. I took the screen out and separated the 2 screens at the bottom and wiped and let dry. I put it back together after it dried and put back in tv, now when it1s on it has a foot and a half circle that is clear as a bell and the rest looks blurred. is there a fix for it or do i have to replace. Where can I find a replacement, I looked on line and can not find any. Thx
2helpful
Fuji Finepix F30 Suddenly takes only all pink screens (no image)
This sounds like one of two problems -
Either an LCD screen problem or a bad CCD sensor.
A LCD screen problem would indicate one of two of the following - it was cracked, or the cable inside is either damaged or moved out of the plug and need to be reseated.
A bad CCD sensor would show a pink screen on cameras, but would also show menus on the screen as well, do you see those? The CCD basically captures the image the lens is seeing and translates it to an image the camera can save. Generally the CCD can not be replaced separately from the lens and will require an entire lens assembly for repair.
3helpful
White and purple flickering vertical lines. No image or sound.
I Hope this helps!
Sony has extended the Warranty for people experiencing picture anomalies due to LCD Panel failure through October 31, 2012.
See here:
http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP.
(any less hurts our averages)
Thank and Good Luck!
No picture, but still displays light
Sounds like a dead screen you'll need to get it repaired. Check if it is still in warranty.
Canon digital IXUS 970IS, pink/purple screen images
Sounds like a CCD image sensor problem, not a do-it-yourself repair, but this would also definitely fall under warranty repair. The IXUS 970IS is a relatively new camera, and thus your camera should likely still be under warranty. Recommend that you contact Canon directly to arrange warranty repair. If in US or Canada, call 1-800-OK-CANON. All others, www.canon.com, select "Support" and then your Region for further info in your local area.
We were watching tv on our Sony Bravia - KDL-W3000 LCD tv and the screen turned pink. We can still hear the show's but the entire screen is pink. Any idea why?
sounds like the lcd control board malfuntioned. call sony and im sure they will have you bring it to a repair shop at no charge
Pink highlights on LCD screen
IT SOUNDS LIKE THE MAIN BOARD IS BAD. THERE IS 2 DIFFERENT VERSIONS FOR THIS SET .AM02 UNITS OR VERSION 0001 UNITS. THE PART NUMBER IS BN94-00695E. THEY BOTH ARE ABOUT $210 + $50 CORE.
DON..
Sony trinitron 32 " purple area on screen
Check any magnatic device near TV which causes purple color on screen. That device can be Speaker, Electronic toy, Watch like that carring piece of magnet inside. Remove that device and turn OFF your TV for half a hour, then power again. Hope the color will be fine n normal on entire screen.
2answers
WS55711 mitsubishi RPS - Dec 2002
This sounds like your convergence correction amplifiers have malfunctioned. These Integrated Circuits often burn out after a few years (STK392-110) they can be replaced with a higher version (STK392-150) However it is important to have the biasing circuitry checked to make sure nothing has burnt out as a result of the ICs malfunctioning. If you have a background in electronics you can repair this problem with very little effort, however if you do not have a background in electronics, I would suggest that you have your TV serviced by a qualified TV technician.
I hope this helps,
Thank you,
Shuttle83
1helpful
Vertical Green/Purple Lines on lower half of screen
I would contact RCA if the repair center dosent know how to troubleshoot this set. But I bet its an eeprom or ground issue. Contact RCA here at 580-634-0151 or At https://www.rca.com/secure/service/contactrca/1,,,00.html Good Luck
Computers & Internet Logo
Top Sony Computers & Internet Experts
Ekse
Michael Thomas
Michael Thomas
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
