Some chargers need to be connected to the batteries before they turn on the charge current. With the charger connected and switched on, check the voltage across the batteries and should be about 26 volts for a 24 volt system. And you can use an amp clamp meter for current flow. WARNING DO NOT SHORT PINS TOGETHER
Any battery left in a charger is still hooked up to a circuit. Depending on the charger this can mean a slow discharge is possible. Ryobi's Maintenance Charge Mode means the charger will 'refresh' the battery at regular intervals, usually every 30 days. A battery's lifespan is determined by how many times it is discharged/recharged so to get 'the longest possible battery life' it is desirable to reduce the number of times a battery is recharged. One way is to use the battery until it is dead or near so another is to remove the battery from the charger when it's fully charged to reduce the number of times the charger refreshes the battery.
Any 4 amp charger you can find will work to charge your batteries. Preferably find one that has an on/off switch on the charger. You should be able to find one on ebay a lot less than what the scooter repair store quoted you Check around your neighborhood someone might have a second charger that they are not using. Since Medicare will pay for a new chair every 5 years someone might have a extra charger laying around. Hope this helps you
Yes you can., You can need to purchase a wall charger for you r NI-Mh battery the model number of charger is kodak K620 for or if you want a travel charger the model number is kodak K640., Or if your battery is special battery of Ni-MH (KAA2HR) make sure that you will purchased kodak K4500 charger., KAA2HR battery will not charge using a regular wall charger., Check first your battery before purchasing the charger
