Question about Tappan Ovens
I need dimensions for an older oven. It is a Tappan double oven model # 11-2969-10-0
Posted by Patricia Lynn... on
ray gallant
    Top Expert:
  • Tappan Master
  • 73,512 Answers
BUY A TAPE MEASURE AND FIND OUT WHAT THE SIZE IS
Posted on Oct 04, 2021
I have a Tappan double oven Model 11-4361-30. I am trying to replace it, and I can't figure out what size modern oven will fit.
You need to measure the opening in the cabinets and then find an oven close to those specifications. More than likely you will have to do some cabinet work as ovens generally are not the same size.
I have an old 24 single wall Tappan oven from around 1985 that needs to be replaced. There is no model or serial number. Where can I go to figure out the measurements of it?
Built in ovens come in three standard widths, 24, 27 and 30.
Look at the installation guide in the link for a sears for the 24 inch and confirm the width of your opening along with the depth. Make sure the new does not exceed your dimensions..
The problem is usually in the height. There is a lip that extends outside the inside dimensions so the over all width and height need not to extend beyond you cabinet. You can jack up the bottom with spacers to minimize any upper gap.
http://i.sears.com/s/d/pdf/mp-tc/10031951/prod_1502240512
Desperately searching for User Manual for Tappan Wall Oven Model 12-4990-00-04.
Hello Owner, thank you for your inquiry!
I understand that you need the use and care manual for your Tappan wall oven, 12-4990-00-04. If the model is older than ten years old manufacturers will not keep that information available. You might be able to perform a search for antique models online for any additional information. -Matt
I need parts for an older tappan wall oven..model Z12-1449-00 ...a thermostat and thermostat knob
It's going to be hard to look up the old model numbers, but there is a number on the old thermostat that might help.I may possibly have one but have no way to look up the specific model.
Jan 21, 2010 • Ovens
2answers
I have a double gas oven and no instructions
I have an O'Keefe & Merritt double oven gas stove. The model number is 72 7242 23. The upper oven is about the size of a large microwave and sits above the range burners. The lower (full-size) oven is below the burner unit and includes a broiler draw below it.
So, when you say, double oven, I wonder if you are just talking about the main oven with broiler drawer (both of which are below the burner unit.)
Mine was a builder-supplied appliance in the new house we purchased in 1986. The upper oven has never performed very well. And, yes the upper oven can only be used for baking.
I have an instruction manual for it, but it doesn't provide that much information. Getting parts for it is extremely difficult, since Tappan is no longer manufacturing this brand. (I've been trying to locate a flat oven ignitor for the upper oven and can't seem to find a replacement that's the same 6-1/3" length.) In the 1980s Tappan apparently purchased O'Keefe & Merritt and marketed this brand for several years. Models originally manufactured by O'Keefe & Merritt in the 1930s-1950s are considered collectible antique stoves!
If you want to email me, I'm at [email protected]
2answers
Wall Oven won't work
I tried randomly pushing 2 buttons at a time, and when I pushed "Timer Off/On" and "Cancel" together it unlocked and is now working fine. The following day it beeped a lot for an hour or so (must have been catching up on previous pushes) but now is back to normal.
3helpful
3answers
Tappan Electric Oven
I have a Tappan double oven range. An older model #316065301
How do I operate the cleaning cycle? I set the start and stop times, Locked the door and switched to clean. The clean light comes on but it doesn't heat up much at all. Never locks. I have misplaced my instructions manual.
Any help would be appreciated.
Barbara
[email protected]
Ovens Logo
Top Tappan Ovens Experts
Dan Webster
Dan Webster
john h
ADMIN Canada
ADMIN Canada
Are you a Tappan Oven Expert? Answer questions, earn points and help others
