Question about Samsung Televison & Video
I have a Samsung TELEVISION. I replaced all the boards, Tacony, power and main board and Infra-Red/Bluetooth board. Now remote will not work. Please help.
The remote worked prior to this event. I tried all the reset button pushes with no luck. I see the Bluetooth connection showing on my iPhone settings and the Wi-Fi works on the TV. I just cannot get the remote to pair with the television. Any help?
Posted by John ONeill on
Aron
  • Samsung Master
  • 1,992 Answers
Maybe the batteries have stopped working in the remote and need to be replaced. Or the remote is broken and you need a new remote for our TV.
Posted on Sep 21, 2021
1helpful
No IR control on Samsung 65in LED TV model UN65H7100AFXZA TH01
Check the remote control first for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
https://electronicshelponline.blogspot.com/
https://homenol.blogspot.com/
https://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]/
1helpful
I have a e422vle Vizio TV. The power board went bad, I ordered a new one and the Tv now is working but the remote doesn't work. Is the remote sensor on the power board?
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV.
http://electro-medical.blogspot.com/
2answers
What is remote code for Comcast cable universal remote?
If it is the original remote control to Comcast Cable box; there is no need set it up with a code. It might have been already set. Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
1helpful
My Samsung TV doesn't show a picture, when there was a picture audio and remote not working. Which boards need replaced?
If there is no audio then most likely your main board. If your red power stand by light blinks less than 3 s then its the M/B. If its more than 3 s then its the P/B.
Not responding after changing old battery
you need to check the battery contact with the battery terminal make sure that the terminal is clean.
check open the cover of your remote and check the solder of the battery terminal from the pcb board use a soldering iron resolder it.
using your cellphone camera test the infra red emmision of your remote control aim the camera to the infra red of your remote.you must see at the screen of the camera that the infra red is lit when any button is pressed..if not the infra red is busted.
2answers
LE26R74BDX blank screen, unreactive TV
Tries change power board,most cases,but some case the main backlight video board it dead,or both power and main backlight video board .My sugestions to u buy both power and main backlight video boards,tries the brand new power board first,if don't work,try it with the backlight video board with the old power board, same prob. tries both new boards.Trouble shoot this way u have base cover have boards in hand,must lose some money for return merchandise,for restocking fee.
4helpful
I have an LG 37LC2D LCD TV that is locked.
Bad filters on the main board or a bad AUX REMOTE jack on the back of the unit (also part of the main board) are the cause of this problem.
Try plugging in any jack that will fit into the AUX REMOTE jack on the back and then pulling it back out. This may fix the problem or remove any dust that may have collected in the jack. If this jack has something plugged into it (or goes bad) the TV will no longer have remote control operation (because it thinks an external remote box is being used). If this does not work then the main board will need replaced.
Note, many repair techs will think the IR board is bad (the Infra-Red Receiver board) at the front of the TV, but this is usually not the case with this model.
Hope this helps, please rate my solution.
My Samsung LN-T3242H is not coming on with either remote or manually. The red power light is on but the TV is not switching on.
When you tried turn on with remote control,the light was blinking?
I think that you need to replace the main board.
3helpful
TV not switching on
Can you hear the sound of turning on?
79helpful
3answers
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Televison & Video Logo
Ekse
Demonic-2011
Demonic-2011
