Won't play. Keeps ejecting. Tv and vhs. Turbo rewinmechanism
I put tape in Will not play. It ejects it. It worked early
    Top Expert:
  • Televison & ... Master
  • 76,799 Answers
Deck mechanism has the fault. sometimes, a loose belt too can cause. sometimes a broken gear wheel might be the cause. anyway, your VHS mechanism should troubleshoot. It is a skilled job. Contact any service technician. If you wish to get some details, http://electronicshelponline.blogspot.com/
https://elektrotricks.blogspot.com/
Search the site by type in the brand name of your set, in its search bar at the right side column, and press enter. See it in Webview by mobile or by desktop computer. Mobile View has no search box.
Posted on Sep 20, 2021
How can the cd player be fixed when it won'r eject a cd on my Mac computer
try ejecting in Itunes. it has a eject button that sometimes overrides the player
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Cd stuck in 2004 VW Beetle
Soo easy just keep playing with it keep pressing the button the same thing happend with my mom and i got it out the way i told you.,DO IT WHEN YOU CAN!! :)
CD Player keeps ejecting the CD
Either Cd is problematic or lens inside of cd player is covered with dust. There is no way of properly cleaning it unless you remove the cd player out and disassemble.
You may try cd cleaner kits but ususally they cant help.
DVD will not play or eject dvd/cd mode will not
Mp3 cd won't play it show {format unsupported} how can fix this problem?
1helpful
My 6 disc changer in my Ford 500 won t Eject or play
well i don't have a 6 cd changer but i have had a few problems like that and all i can tell you is using something to unjam as soon as you hit the eject has been working just fine for me .......hope it helps a bit
Won`t play games
xbox 360s are always haveing problems i have had 4 so far and they have all had differnet problems wot i found was easyer was 2 send it bak to microsoft and they just replaced it but the problem might be that it just needs a clean or sumthing has got stuck insinde and is just causeing them to eject
Televison & Video Logo
Top Televison & Video Experts
Ekse
