When i use the disc it states there is no valid
There may be a problem with the way the printer software created the USB protocols in your system.ini and config.sys files. We can check this by going into the "Device Manager." Please follow the steps given below:
1. Right click on the "My Computer" icon and select "Properties."
2. Click on the "Hardware" tab. Go to the "Device Manager" button. Click on the "+" next to "Universal Serial Bus Controllers." The host controller listed here is the software that runs your USB ports. It is linked to a chipset on the motherboard that requires frequent updates to satisfy the needs of newer products, such as your printer.
3. Look at the name of the host controller. Some of the more common names are Ali, Intel, AMD, Via, and SIS. You may have to contact your PC manufacturer to get help updating these specific controllers to the newest driver set.
4. If you are the PC manufacturer, you will need to look over your motherboard's manual to determine who makes the chipset for the motherboard. Again, Ali, Intel, AMD, Via, and SIS are some of the more common manufacturers of chipsets.
5. You will also have to look for either "Lexmark USB Printer" or "Other Devices" present in the Device Manager.
6. If you see anything with "Lexmark..," then click on the "+" to its left and look for "Inkjet Color Printer" below it. If it is there, double click on it. It should report in the next screen that the "Device is working properly."
7. If you see any question or exclamation marks listed in the Device Manager (small yellow icons next to the listings,) double click those items to get information on what is wrong with the items.
8. Then please let us know which items have these marks, and what errors they are reporting. This information is useful for troubleshooting your system.
9. If not, or there is nothing present, you may have to uninstall and reinstall the printer driver software, or download a new version from our website.
what is a Freshmark?
what country is this? sounds like 12,000 miles from here, USA
here it is BACON,..
are you in AFRICA, asking about a PC, of some kind , only sold there? say so. is best.
brave up and say country, as manuals for PC are based on , you guessed it COuntry.
India., down UNDER, UK, EU, where>
most times and error like that and (wrongly stated, by it) is the HDD is dead not he mobo.
the motherboard can not store any software (firmware bios yes)
remove all CD and DVD? and boot.
remove all USB drives or thumbdrives and boot
cold boot the PC? hold power button 10 seconds release button?
run PC diagnostics yet.
check the RTC CMOS coin cell battery for dead
test the hDD for failing smart tests.
and more we have over 20 tests to find what's wrong on any PC. ask.
NO MODEL told nor maker of PC told and you did post to PC. help
Native Arabic (is this you?) yes but where are you parts (spares) for PC are best found in your county. see?
is it a micro processor for some mystery application ?
It could be a hickey
it might have a eeprom on the mother board ?
NO PC TOLD ,model nor words laptop, desktop, notebook ,tablet, or pad. no clues.
if confuses post a photo of it and we can play guess my PC.
